Waterline and ballasting for SLEC Perkasa kit
Home › Forums › Building Kits › Waterline and ballasting for SLEC Perkasa kit
  • #104429
    Chris Gorbutt 1
      @chrisgorbutt1
      Hi folks, I am building a 30” Perkasa kit as produced by SLEC. I am at the stage of marking out to paint the waterline/lower hull colour. A test float in the bath indicates it is going to need quite a fair bit of ballast to sink the hull to the plan indicated waterline. My question is this is it better to invent my own reduced waterline for the lower hull colour or ballast it down to the plan one and I guess accept some reduced performance due to the weight? Any thoughts would be welcomed. Thanks in advance.
      #6357
      Chris Gorbutt 1
        @chrisgorbutt1
        Question about waterlines and ballast on fast patrol boat
        #104434
          Hi Chris,
          This kit was designed by the late Dave Milbourn and was his last project. Normally he would have provided very detailed instructions but I don't think he had the chance to complete the job which was finished by SLEC. I assume that there is nothing in the instructions you have concerning this?
          The recommended powerplant with a brushless motor and 3S LiPo battery is pretty poweful but also lightweight. A 'traditional' brushed motor NiMH setup would be a lot heavier so it is reasonable to assume some ballast will be needed.
          Perkasa is intended to be a near scale model so if you paint the waterline anywhere other than as indicated it won't look right. It also means that performance should be near scale in appearance too, this is not intended to be a model speedboat and if overpowered it may not perform properly anyway!
          Did your bath test include all the internal mechanics and electrics plus all the external fittings and superstructure?
          I think your best bet is to provide for removable ballast so that when the boat is complete and working you can adjust it to give the best balance between speed and appearance on the pond.
          I built both of Dave's Fairey powerboat designs and reduced the battery to 2S on the Huntsman as it was simply unrealistically fast and unstable on a 3S, even with some ballast aft to improve the trim.
          There are plenty of photos online of this type of craft which show what they look like at speed.
          Charles Oates
            @charlesoates31738
            This is a personal view, others might disagree. I would not add any ballast at all, if you can avoid it, maybe just for trimming the model.
            I'd do a flotation test, and mark a new waterline, if it doesn't seem ridiculous I'd paint it there. If it does look a bit silly, I'd compromise and lower the waterline as much as looks ok. Once the model is finished and working I doubt you'll ever give it any thought again. Once you see it powering over choppy water and see a graceful high speed turn you won't give a fig for the waterline. Great models and great performers.
            Charles.
            #104437
              Chris,
              I've just remembered that Dave Abbot reviewed another kit of Perkasa in 2009 and the article included a number of on the water photos of the model in action. You can see it nhere:
              The waterline appears to be in a similar place to the SLEC model and the boat at rest seems to be floating down to it.
              You can see clearly what the model ought to look like in motion and note Dave Abbott's comments about getting the planing effect just right.
              Dave Milbourn wouldn't have put the waterline where he did for no reason, he was a top designer of this type of model. He used Dave Abbott's photos when designing his SLEC kit, I know that because I have just found the email Dave A sent me back in March 2020 to pass on to Dave M!
              I would definitely leave the waterline where it is and add whatever ballast you find is necessary. I don't think you will have any practical performance issues with that power set up. I found that my Huntsman handled a lot better with a bit of weight inside as it improved stability, particularly in the turns. It looked a lot better too!
              Chris Gorbutt 1
                @chrisgorbutt1
                Thanks for your replies Colin and Charles. Much appreciated. Perhaps I should wait til I have built and added all the externals such as the guns and lockers etc and then do a bath test again and then take a vew. Removable ballast sounds like a good plan if i do add any. Thanks again.
                #104439
                Chris Gorbutt 1
                  @chrisgorbutt1
                  Thanks for the link Colin! Will take a read through. Much appreciated.
                  #104440
                    Chris,
                    You might be surprised at how much all those fittings add up to! Dave was always complaining how many there were!
                      If you have a look at Page 16 in Albums you will see some pictures of Dave's build and an angled shot of where the waterline is.
                        Is this the Album you mean Chris?
                        https://www.modelboats.co.uk/albums/member_album.asp?a=53845
                        Chris Gorbutt 1
                          @chrisgorbutt1
                          Thanks chaps for those links. The pics in the album of Dave’s will be most helpful. I have spent some time adding some pictures of my own build into my album this afternoon…
                          #104446
                            You are obviously making a great job of the kit, do keep up with posting the images. One thing I learned from Dave Milbourn when building the Faireys was to follow the instructions implicitly. Trying to go 'off piste' simply invited trouble due to the precision of the kit components.
                            I was asked to review the kit myself but I had other commitments and it is not really my type of model although I can still appreciate the finished result.
