Vic Smeed’s Silver Mist
Home › Forums › Scratch build › Vic Smeed’s Silver Mist
  • This topic has 991 replies, 11 voices, and was last updated 1 month, 1 week ago by Colin Bishop.
Viewing 25 posts - 626 through 650 (of 992 total)
  • #67678
      As a matter of fact, Banjo……I've been eyeing up the contents of the VGC cabin, for goodies
      But can't bring myself to do it
      I will have to do something about the empty space though
        Hi Bob
        The original had a Kent circular clear view screen in the port side front window, which I have used an acetate circle with a 1/16 brass rivet in the centre, at your scale you could arrange a motor & belt drive to it
          Very nice and witty too……Thank you, Ray
            Hello Captain
            I was looking at the strange cube shaped objects on your last photo and couldn't figure out what they were so I showed Jane who said "they are sanding blocks" after some thought I replied "but they cant be sanding blocks……not on Bobs Silver Mist".
            Looking more closely I thought 'good heavens they are sanding blocks' and feeling like St Paul on the road to Damascus (post epiphany) I had a sudden flash of all consuming realisation.
            Bob is sanding his model
            Being of such national importance I have alerted the appropriate people and a reporter from the Manchester Evening News will be around later this afternoon with the ITV local news booked at 5.30pm.
              Oh….Very droll
              Thank you, Paul…….All in good fun, eh?
              Have you tried rubbing paintwork down with a Liquorice Allsort……….It makes a right mess!
              Finally got round to ordering the brass for the railings……..Should have done it weeks ago
              All the best, my mate
              Diede van Abs
                @diedevanabs87670
                Hi Bob,
                Nice work on the decks and railings, that looks fab. Also good to see the filler patches on the hull, I think it'll turn out brilliant once you got all the nicks and bumps sorted. I am imagining this vessel on the water with a nice satin or matte finish, that would suit the boat good.
                #67802
                  Many thanks, Diede
                  All in good time
                  Current lack of progress is down to us getting out in the Campervan again………Betws y Coed, this time
                  Came back to find a PO card behind the door………The railings wire has arrived!
                    Hi chaps
                    The PC has upgraded itself this morning for what seemed several hours and the whole system is in apparent chaos! Windows 10 has a lot to answer for
                    The picture section, somehow imported a vast number of old photos from outer space!
                    Have now erased them all, but be in trouble in a few minutes
                    We`ll see…….Here goes……
                    Finished the cabin railings now, using the correct brass wire
                    They may need levelling later
                    Well, I seemed to have been successful after all!……….Now for the rear railings
                      Hello Bob
                      The railings look quite nice but what are the circular bases made from?
                      You could try dumping Win 10 and revert to Win 7
                        Hello Paul
                        Trust you to spot the chrome washers!………I could make brass ones if deemed necessary?
                        With reference to the Win10 update….
                        When I switched off last night, it said……."Switch off or update and switch off"………So without realising the consequences, I selected…….Update
                        So the update is down to me
                        The masses of photos that appeared must have come from the camera card which was supposed to be wiped clean every time I downloaded a photo!
                        Can't really go back to Windows 7……….I haven't the knowledge these days
                          Actually the chrome looks just like real base plate covers so well done on the authenticity.
                          #67823
                            Well!……..That's a nice surprise!
                            Thanks a lot
                                Just an update of the current situation, for my faithful band of browsers
                                Nothing worthy of a photo at the moment, chaps
                                Working on the rear deck planking, prior to fitting the rear handrails
                                Not looking too clever at the moment, due to unevenness, hopefully, the Jolley Boat will hide most of it?
                                  Having to use brute size 36 grit industrial abrasive on the deck…….Due to having panel pinned a few planks down with fine brass panel pins…………Which have turned out to be steel!
                                  But we are getting there now
                                  #67875
                                    You could have used a nail punch to push the nails below the surface.
                                    All
                                    Beware when buying 'Brass' fittings from DIY shops as the majority of items are just brass plated steel……..real brass fittings are expensive and very difficult to find. Take a magnet with you when buying as this simple test could save you time and money.
                                      Did you know that an old electric toothbrush makes a great micro-sanding tool perfect for getting into those hard to reach little corners.
                                        That's a useful tip, Paul, I'll bear that in mind, but I do have a special gadget that does the same action
                                        Made by Bohler, it has a 10mm square patch of abrasive, that oscillates……..Got a photo in the files somewhere
                                        I've made do with a brass wire brush for now
                                        Now working on the rear hand rails at the moment
                                        Pleased to report, that our pal Duckie has bought himself a wooden barge kit
                                        That should keep him occupied for the next few months
                                        Power sander
                                        #67930
                                          Work in progress
                                          Brass work finally finished………Wood capping yet to be shaped and finished
                                          #67939
                                            The bamboo decks look nice especially with that yellow/green tinge. Its a material that I have never used before so how difficult is bamboo to work with?
                                            Does it splinter or shatter when cutting and how well does it sand?
                                            Currently feeling fed up as I cant decide on a winter project, Ryan would like me to do something futuristic so I have been dabbling again with tilting hulls and the Banshee design
                                              Bob Abell…..Outside Broadcast…….Royal Oak…….Betws y Coed
                                              Hi Paul
                                              On our eighth outing this year in the Campervan
                                              The only source of WiFi is in the Oak, so we're here against our will really!
                                              Working with Bamboo does cause a sort of fluffy skin rash…….We've both broken out in black and white blotches and keep speaking Chinese!
                                              The wood has a sort of oily texture ……..Ying tong huddle hi po!
                                              That's why the deck has a yellowish tinge!……….Yik Yak Tong filed Lice and hips
                                              Edited By Bob Abell on 02/10/2016 19:33:47
                                              #67952
                                                WiFi………… That has to be the best excuse for having to be in a pub beer
                                                  Bob Abell News at Ten
                                                  Slaughter on the A5
                                                  Regret to report, that on the journey home from the Land of the Mist and the Male Voice Chiors last night, we were driven off the road by a wayward trucker, who thought the Welsh folk drive on the RHS………Some do actually and had to take instinctive evasive action, causing us to have a very unpleasant altercation with Thomas Telford's stone wall
                                                  Resulting in the coach work getting a good rub down with number 2 grit abrasive material!
                                                  Our first MTA in 47 years of Caravaning……..The Yorky Man failed to stop btw
                                                  Happily, Kevin the Kampervan is undergoing emergency treatment as we speak and should be back on the road again, shortly
                                                  Could have been much worse
                                                    Like many other folk I have installed cameras in my car simply to protect my no claims bonus when some nutter pulls a stupid stunt.
                                                    Mine cost under a tenner each and come on automatically when I start the car, 40 hours of full colour data is stored on a removable flash card.
                                                    http://www.amazon.
                                                    Edited By Paul T on 06/10/2016 11:09:07
                                                    #68011
                                                      That's sound advice Paul…….Many thanks
                                                      I was only looking at them, last week in PC World and marvelling how inexpensive they were!
                                                      I'll get a couple right now……..At only £8.95 each!
                                                      In this case I won't be making a claim, since the bill is comparatively low
