Varmint plans
Varmint plans
Home Forums All things floating Varmint plans
  • #72796
    Eddie Lancaster
      @eddielancaster
      Hi all, I have just returned to model boats after around 35 years (I got hooked on the engineering side after building a steam plant to power a model of Cervia.)
      Having just had a hip replacement and waiting for another I decided I needed something a bit lighter to handle than lumps of cast iron for a half size traction engine! so having spotted the picture of Varmint on the cover of M.B. I went for it, Paul from MB kindly sent me the pdf of the plan that I had printed off but it is only one sheet of the hull plan, side elevation and the frames but no dimensions. This has not been a problem so far, the hull is now nearly finished but I will need measurements for all the sail fixings etc. on the deck, can anyone help?
      Thanks Eddie.
      #4422
      Eddie Lancaster
        @eddielancaster
        #72798
          Hi Eddie
          I would have a look at Dragon Force RG65 yachts images on google to give you an idea of the sheeting set up, and all the setting out points are on the drawing for the rig, the mast has no shrouds, the back stay stops the mast falling out if inverted. Which details/dims were you looking for ? I thought the build article photos were excellent by John.
          Regards Ray DF65 no.943
          Edited By Ray Wood 2 on 22/08/2017 14:27:56
          Edited By Ray Wood 2 on 22/08/2017 14:29:42
          #72800
          Eddie Lancaster
            @eddielancaster
            Thanks John, I agree the article is good and the photos show a lot, I have just looked at the drawings again, your right the positions of the eyes etc. are there, just a lot fewer than the Dragon Force boats!
            Many thanks
            Eddie
            #72801
              Hi Eddie
              The best idea for sheeting on the DF65 is the running line on the deck tensioned with elastic to which the main and jib sheets are attached, I'd avoid under deck sheeting arrangements they tangle easily I find. Happy rigging !
              Eddie Lancaster
                @eddielancaster
                Hi Ray, first my apologies for calling you John, another senior moment, they seem to be getting more frequent these days!
                Yes I had wondered what the elastic cord was for in the spares list for the DF65, I will be fitting one.
                Thanks for your help, I now know where I am going with this build and everything is on order to complete my boat.
                Regards Eddie
                #72813
                  Hi Eddie
                  You will have good fun sailing this little yacht, variety is the spice of life I have a 75% complete 5" gauge Boxhill Terrier which has been on and off the bench for about 8 years so far
                  Eddie Lancaster
                    @eddielancaster
                    Hi. All
                    I have just cast the 2 lead weights for the keel bulb for Varmint, I turned the plug on the lathe to a close copy as drawn on the plan, but my problem is, that one side, after cleaning up, weighs in at 500 grams- the weight that both pieces should be, so, is 500 grams the correct weight for this size of boat or mine at double the weight?
                    Once again many thanks for any help you can give me.
                    Eddie.
                    #73729
                    Ian Bell 1
                      @ianbell1
                      Hi Eddie,
                      If you get stuck, Pj Sails sell a RG65 precast lead which weighs in at about 485 grams ready to fit to the fin. That is about in the middle of the Varmint's range and I think that it is about £18 to buy.
