Well, sparse on the boaters front today, 4 others. Nice crisp day, got quite tolerable as the morning went along, brilliant sunshine and no breeze whatsoever.
LFM and Invincible. Going well, lots of leaves in the water.. a bit odd, as the LFM doesnt push them aside but rather lets them slide under the hull to be caught on the prop. Not that i had and "incidents" or stalled props, but you could hear the noise of them inthe prop at regular intervals. The carrier is such fun, I will say it again. The accelleration is remarkable as is the stopping power, and it just BEGS to be chucked about. And I do!! what a wash!! such fun (sorry chaps, I will try harder not to swamp you all next week)
Mr T had a bad time of it. HAving popped over yesterday to sort out the rudder issue (the servo was full over one side, the arm needeed moving, twice) he turned up, put the battery in and screwed everything down but then discovered he had NOT connected the battery, so put the boat on the park seat, conneceted it up..whereby the motor started wizzing away .. and promptly sheared both blades on the seat!! He is not the only one to have done this, I have had TWO props go and I have seen others do exactly the same thing.. It is very easy, just pop the boat on the seat to adjust something.,.. and..
I know you are ALL experts out there, but it is a tip..having mounted the servo where you want it to be and having put the arm on and connected it to the rudder or whatever….take the arm OFF and then connect the reciever and let the servo reach its normal position.. THEN put the arm back on.
Its a bit like worrying about having the rudder dead straight, dont bother, get it somewhere near straight, as you are bound to have to alter it when you start water trials ..all boats veer one way or another, be it due to prop-torque of slight differences in the hull shape or ballasting/whatever.
Mr T`s prop was a plastic item bonded to a brass collar-with-grub-screw, on a plain shaft end so were not able to get him going. As far as we could see it was a standard 4mm shaft so he should just need to get a replacement shaft with a normal thread on the bottom and away he will go.
Trevors project.. interesting. He is running out of room to fit the gear, or at least not specifically running out of room but faced with several options about gear location. We ummed and arred, and to be honest, it looked to me like anything would do, it has to be stuck in the water for a run and THEN we should see what needs altering. With something odd you just cannot predict how it will behave. The Sunderland started to go nose down when i took it for its first trial and put the power on,,took me by suprise I must say, and I had to alter several things and remove the water drive before it was running correctly.
Edited By ashley needham on 18/11/2012 18:52:56
