You are quite correct, there were several MTBs and MGBs built during the War which had all the props turning in the same direction. One of the main reasons was a short supply of the reverse gear boxes. To cut a long story short, after the War, they did experiment with configuration of rotation of propellers – they found there was a slight improvement in speed with all the props turning in the same direction – but – only a slight improvement.
One of the most notorious vessels that Royal Air Force had built was the 68 ft RTTL It originally started off with 3 props but then was reduced and re-engine to have 2 props (all rotating in the same direction) and this vessel was renowned to have prop walk especially when diving off the top of a wave at speed. On numerous occasions, several of these vessels, split the hull at the bow. So, what Vosper tried to do for one of the fixes was add an extra layer of planking to the bottom and then they experimented with an aluminium hull.
If I can find the pics, they will follow
John
Edited By bluebird on 12/03/2017 19:01:10
Edited By bluebird on 12/03/2017 19:01:37
Edited By bluebird on 12/03/2017 19:02:04
