At last, Colin!……..You've finally emerged from the primeval soup!
Welcome to the world of machinery
You'll find the lathe very useful for all sorts of jobs
Starting with sanding dowels and masts etc………..Making prop shafts and prop tubes……Bosses and bearings
Items made from brass are a doddle, but steel is a different kettle of fish……On a hobby lathe, it's a bit unpleasant with the red hot dwarf etc
You will need a few turning tools……..Loose tips preferred…….Taps and dies………Drill chuck and drills and a Slocomb centre drill for shaft ends
If your lathe is like my Chester lathe you will need a few low amp fuses…….eg……0.5 amp
should you overload the lathe…..The printed circuit board fuse will blow first……….Not the mains plug!
Just take your time and play about with simple jobs at first
The usual safeguards……Wear goggles, keep rags out of the rotating area and don't wear a tie
All the best…….Bob
