Ashley, hull design plays a huge part in the flow through a propeller and hence its pushing power. This is precisely why a lot of ships now use pods because the propeller can sit in a much less restricted water flow.
Another popular recent development is to have little clearance between the propeller boss and the leading edge of the rudder and incorporate a fairing into the rudder to promote better flow through the propeller.
Ship design at the back end is always a compromise between wanting the squarest shape for the purposes of available internal space and the finest shape to enable the minimum restriction to water flow through the propellers.
Then you can start looking at the different efficiencies of Voith Schneider versus propellers and it soon becomes obvious that the measurement of amps against bollard pull can be misleading if you do not take all the other variables into account as well, which can soon get very complicated.
