tapping a shaft
tapping a shaft
Home Forums All things floating tapping a shaft
  • #25481
    ron hawes
      @ronhawes49865
      i need to cut a thread 4mm on my shafts im using piano wire, but i cant get the die to start correctly ive cut a shamfer on the end but what am i doing wrong ??
      #3506
      ron hawes
        @ronhawes49865
        #25482
          Ron!…………..You`ve ruined your die!
          Piano wire cannot be screwed…..It`s too hard!……..Sorry
          ron hawes
            @ronhawes49865
            lol ok bob maybee thats my problem!!
            could you run through how to do i though i havent tapped a thread in years
            #25486
              OK, Ron…………I assume your making a prop shaft?
              Assuming you haven`t got a lathe either?
              Get a suitable length of stainless steel…….From the model shop or Engineers suppliers
              You will probably need to buy a new die too!…….Your old one will surely be damaged
              File a chamfer on the end of the shaft………Grip the shaft in a vice, protect the shaft  from damage using brass or ali vice pads
              Place the die , in a die stock, on top of the shaft……Press down…….Rotate the die `till you feel the thread just starting to bite, keeping the die perfectly square and level, slightly reverse the die in order to break the chip being formed……..repeat this process till the thread is formed.
              This process takes a lot of practice…….The greatest problem is keeping the dia level and square to the shaft axis.
              You will find after a few bum starts that the tread is ok after a short while. You could saw the dodgy bit of thread off……If you do, keep the die on the shaft, during sawing….chamfer the sawed end and unwind the dia…….and that should be ok
              Best of luck………………Bob
              #25489
                Notoriously tricky this operation i find, tricky to get that die dead square, even on “easy” material, brass or whatever.
                Needs practice…sadly lacking in my case .
                  It can be done in a vertical drill
                  Grip the material in the chuck and place the die and holder on the base……..Wind the drill head down and get crackin`!……….A bit of dexerity is required though!
                  It`e eay in the lathe though……………Bob
                  #25495
                    Bob…I LIKE that idea! you are a real engineer.
                      Thanks Ashley
                      I sometimes tap holes out in the drill, in the same way….You can get them dead square dead easy!
                      Btw, Ron…….The correct terminology is….We screw a shaft and tap a hole
                      ron hawes
                        @ronhawes49865
                        thanks ashley i think the last time i SCREWED a shaft was at school some 30 yrs ago !
                        ill get some new 4mm and try again
                        thanks for the replys
                        #25890
                        Phil Winks 1
                          @philwinks1
                          If like me you have some off those fairly cheap non adjustable dies the taper on the shaft needs to be quite long I usually form it on a bench grinder but then I’ve lots of experience with grinders also if the steel is a tad hard I heat to cherry red and cool to make it easier to get the thread started also start with the shaft a good bit longer than needed so there’s plenty to trim off.
                          Phil
