Hello all, having got as far as installing R/C gear and batteries in my Fisher 34 I need to air a thought or two yet again, sorry!
I have refered to DM's very informative tech-tips about 'electrickery' installations etc.
I assume that it's OK to use the fuse holder and fuse as a 'switch' in the '+' wire instead of installing an actual switch in this '+' wire -from the battery to the Sp controller?
Removing the fuse is not quite as simple as flicking a switch but I don't want to use up even more space 'under the bonnet'. Switches are not as reliable as removing a fuse I suspect?
The speed controllers (2 of them in fact) are Graupner Navy 30A. with BEC. I've removed the BEC wire from one of them. As DM writes, the switch on the Spd controller controls the signal to the Rx, it does not switch off the power supply from the battery to the controller.
I read elsewhere that winch servos (3 of them) may on occasions require more current than the BEC can supply. I don't think more than 2 winches will be moving simultaneously so I expect the BEC will be OK.
If I notice trouble here, I have dedicated a Rx battery available which can be installed later -and remove the other BEC supply so that controllers only supply the drive motor and bow thruster, not the rudder servo and 3 winches.
Any comments/advice/suggestions are welcome.
George
