Hi Mark..
I has not tried in the modelboat. The propeller sleeve is in lowest part of the gearbox, also no problem to install in the modelboat. The turbinehouse is easy to dismantle from gearbox with locking screw on gearbox when the gearbox is installed in the modelboat. Running time is about 15-20 minutes with this Saito boiler showed in the video. I learned out the 2 blade graupner propeller gave the better thrust than 4 blade propeller due too big diameter/pitch showed as in the video.
The oil in gearbox is critical due drag in oil caused by viscosity in oil, i learned the gear oil is robbing power from turbine and i tested miscellaneous oil. The recommended oil in gearbox: sewing oil or diesel oil as lubricant. The level of oil will be about 1:3 of the diameter of gearwheel for propellershaft. Under running, the oil will spread overall in the enclosed gearbox. No sign of abnormal abration in gear tooth or bearings.
I wrote about measuring results of the turbine in steam pressure and difference viscosity of oils, also the turbine ran without load.
Diameter of the turbine wheel: Do not make too large turbine wheel diameter due the revolution will be reduced with increasing diameter with same amount of steam and pressure. We need high revolution to produce enough torque out of the turbine before we are reducing to usable revolution for propeller with high torque with good thrust in water.
Gear: Use hard steel gearwheel to example from drill machine or similiar against abration due high revolution.
The plan i used to my turbine for modelboat as here.. **LINK**
