Smoke generator
Smoke generator
Home › Forums › All things floating › Smoke generator
  • #42851
    Andy Hustler
      @andyhustler32076
      A few years ago i seen a guy from Christchuch , in Newport , Gwent with an amazing smoke generator run off tap water .My brother is after one for his trains , yes i know sad man but someone has too , Any way any one out there know how i can contact this guy ???
      Many thanks
      Andy from Cardiff
      #4022
      Andy Hustler
        @andyhustler32076
        #42853
          Something like the Foggy on this site? – **LINK**
          #42913
          Telstar
            @telstar
            This Site does Model Railway Gadgets and gismos
              Posted by Telstar on 12/08/2013 13:36:53:
              ………but no WATER based types, as per the original question.
              #42919
              curly
                @curly
                Andy if you go to maplins you can buy a mini fogger and then you can make your own
                #42988
                Telstar
                  @telstar
                  Malcolm If we wish to be pedantic, original question was
                  "Any way any one out there know how i can contact this guy ???."
                  The type of steam generator used depends largly on the size of model. I have a friend with a 3Guage pacific class loco with a good way to provide smoke (steam actually) through the funnel its called a boiler. Very realistic
                  #42990
                    The guy is most likely to be Mark Windless, who runs Marks Model Boat Bits from his home in Christchurch, Newport, Gwent.
                    You may contact him via the MMB website for which the link appears in Malcolm's posting above. Have a seat available and maybe a supply of coffee if you telephone him. His enthusiasm knows no bounds!
                    Other water-based steam/smoke generators are available. Model loco units tend to be the oil-burning type.
                    Andy Hustler
                      @andyhustler32076
                      Many thanks to all who replied to my requesr for info , i have passed it on to my brother .
                      #43141
                      Ian Gardner
                        @iangardner62867
                        Now that you have the info you require Andy, I hope you don't mind me piggybacking your thread with another question about smoke generators.
                        I have a Graupner smoke unit and a Hunter Systems one. Does anyone know if the distillate used is the same in all these units. One is much cheaper than the other! I know the obvious answer is to ring Hunter Systems but I thought I'd ask here before bothering a busy man. Another suggestion might be to try it- but I don't want to gum things up if they aren't compatible.
                        Anyone know please?
                        Edited By Ian Gardner on 19/08/2013 18:40:57
