Hello Brian,
difficult to see the true sail shape in your images, but she does look quite nice on the water. From what you have said your boat likes to sail up wind, which is good.
To run down wind you will really need to pay out the sails quite a bit. There's two things could be happening for her to come back up wind when on a run. The elastic not strong enough, so the sail is always pulling the rudder hard over putting her right round, or of course, too strong and the rudder not coming into use at all.
Looking at the set up in your image 1020194 the rubber band appears to be very short? and a long way from the tiller arm. On a normal Braine quadrant, the band passes beneath the quadrant, so that the turning moment of the quadrant (your tiller) is through the band itself. The rubber band is NOT attached to the Braine quadrant at all, it is strechted along the fore/aft centre line and the quadrant is over it, with the rubber band passing through the quadrant's loop. Secondly, the running sheets are attached at the outer ends of your rudder quadrant, which will give a very big turning moment for very little sail pressure.
Try attaching the sheets closer to the rudder stock and record what happens. Then increase the rubber band size and tension. It's quite surprising just how much band tension is required to hold the rudder dead ahead, especially in your system with the large lever force supplied by the tiller arm.
NOTE take care that over tensioning does not break the tiller!!! I suppose thats why we set the band through the Braine quadrant passing it through a brass loop, a rubber band will hardly break a brass/steel quadrant. You may have to try that too, and just have a down peg under the tiller arm that has a hole for the band to pass through such that the tiller stops up against the band from either side. This can also assist in keeping the tiller midships on a beat. (it's how my own yacht is operated, I do not lock the rudder, but increase band tension for a beat.)
Kim
Edited By Kimosubby Shipyards on 06/09/2013 11:15:26
Edited By Kimosubby Shipyards on 06/09/2013 11:21:55
