hi there, Mr Milbourn – well I will give you 7 out of 10 for that recommendation for the Scroll saw – I ordered one on line and its just been delivered today. Sadly I had to return it due to the framework that holds the tilt table in – the alloy had cracked on the mounting lug, making the table unusable – I returned it to our local store who swapped it for me with no problem.
Overall, it took some setting up; to get the blade to cut straight. Once set up, it seems quite happy to cut half inch plywood no problems. Also I have managed to fit the fretsaw blades, which I use for my hand fretsaw, into the new Scroll Saw. Its a faff on – but in the end got there.
I am going to do a couple of amendments to the clamping arrangement of the blades, so I can clamp the fretsaw blades better – but me overall opinion from a dye hard fretsawer – its pretty good – be ideal for me next project which has a lot of frames to cut out John
