Hi Stephen, I had a similar problem with a RTTL, but I hated the idea of adding extra weight, it just dulls the performance. My radio has rate switches so I set one to give reduced rudder throw for normal running, and I can switch it out for slow running/ docking etc. It's a pretty common way to set things up.
With an older build, I didn't have that transmitter so I just reduced the rudder throw a little so the turns were a bit gentler. Easy to do using a different hole on the servo or tiller arm.
Charles.
