Rubbing Stracke’ss
Rubbing Stracke’ss
Home Forums Scratch build Rubbing Stracke’ss
  • #11207
    Roger Simmonds
      @rogersimmonds35858
        What do other modelers use for the rubbing stracke’s on their fishing boat hulls, I need to get a 5/16 strip and just wondered what you use.
      #11268
        Hi roger
        I use steamed hardwood such as mahogany or oak.
        I machine the wood to the required profile and make it slightly longer than required then I put it in a home made steam chest that is powered by a wallpaper steamer, this heats the wood up enabling me to bend it without it splitting.
        Its a very old fashoned process but it works very well.
        If you want more technical details then please let me know.
        All the best
        Roger Simmonds
          @rogersimmonds35858
            Hi paul
                         I guessed that you said it right, it is an old method and of course the proper way that traditional boats and ships were built.  I was more or less thinking on any new ways that people have such as rubber (don’t think this would look right) or plastic or any other material that they use.
          #11308
            Hi Roger
            You could always use silicon rubber (bath sealent) if you squeeze out a length on a piece of glass then use a former / template cut to the right shape to make the silicone the right profile.
            Let the silicone set then remove it from the glass with a sharp blade you will then have a perfect rubbing strake. It sounds a bit "Heath Robinson" but it does work very well. If you dont have a suitable piece of glass (I use the back door) you can use a piece of kitchen worktop
            I sometimes use industrial door seals as rubbing strakes for example on my Trent Lifeboat (have a look on my gallery)
            Manxman
              @manxman
              Hi Roger,
              The way Paul mentions is ideal, I’ve used this method myself, plasterers also use this method to make coving.
              A very good site for any kind of seal or strake is …. http://www.sealsdirect.co.uk/
              they make rubber extrusions of all shapes and show how to make a non standard profiles from standard ones.
              Cheers – Ken
              #11314
                Hi Ken
                How is the latest matchdtick model getting on I have looked for progress photos but alas I have not seen any.
                Thanks for the endorsement on the rubbing strakes the method sounds daft when you write it down but as you say it works a treat.
                Have you had your day out with our teacher Vinnie yet?
                All the very best
                Manxman
                  @manxman
                  Hi Paul,
                  Yeah – but SWMBO wasn’t too happy – I used a bedroom window ! – but I did clean it before and after use. – Silicone – best filler/adhesive around, I’ve used so much of this I swear if you were to pick the house up and drop it – it would bounce!
                   ‘Pacific Light’ – has come to a stop for the time being, though I have finished the aerial bridge along with the small mast, fire monitors and railings that go on it, just no pictures as of yet – busy working on the house in preparation for selling (hopefully moving to warmer climates in Crete toward the end of 2oo8)
                  I have 2 weeks off over Christmas, and if SWMBO thinks I’m refitting the kitchen then, then somebody’s going to be disappointed ! – I’m locking myself in the shed (with a bottle of Teachers) for the duration ….
                  Cheers – Ken
                  #11321
                    Crete sounds fantastic but will you have to change your tipple to uzzo??
                    #11337
                    Sam Vimes
                      @samvimes38365
                      Roger
                      Paul showed me how to steam timbers when he was working over here, it is a very simple process (but very hot) and the results are really very good.
                      Sam
                      #11344
                      Roger Simmonds
                        @rogersimmonds35858
                          I will have to try this silicone method it sounds as if it has a lot of uses. thanks for replies chaps.
                        #6411
                        Roger Simmonds
                          @rogersimmonds35858
