A Hitec HS785HB will probably be a drop-in replacement. A Kingmax 6 turn winch is smaller and will generate the pull required, but being smaller is running much nearer its limits. The Hitec carries a larger diameter drum, so its 3 and a bit turns is fairly equivalent to the Kingmax's 6.
A bit of searching for a Futaba 8336 (I think its the same animal) turned up this spec –
Specification:
Dimensions: 59.4 x 29.0 x 52.2 mm
Mass/weight: 110.00 pond/g
Operating voltage: 4.8 – 6.0 Volts
Nominal voltage: 4.80 Volts
Nominal voltage: 6.00 Volts
Torque: 80.00 Ncm Torque: 100.00 Ncm
more Specifications:
Operating voltage:´4.8 – 6 Volts (from receiver battery)
Current drain approx. Idle 9.5 mA – No load 230 mA – Nominal load 1.4 A
Drum Ø:´38 mm (winding Ø
Winding travel: approx. 12 cm/revolution
Revolutions: approx. 2 – 5 (4 revs. with Futaba systems)
Torque: 100 Ncm corresponding to:´approx. 11 kg with 17.5 mm drum approx. 5.3 kg with 38 mm drum approx. 3.3 kg with 60 mm drum
Suitable for sail areas up to about 0.65 m 2 with the 38 mm drum.
Edited By Malcolm Frary on 11/12/2021 10:39:56
