Restricted servo movement
Home › Forums › R/C & Accessories › Restricted servo movement
Viewing 25 posts - 1 through 25 (of 25 total)
  • #5208
    lnvisibleman
      @lnvisibleman
      #39054
      lnvisibleman
        @lnvisibleman
        Hi folks
        I have just puchased a seconhand r/c set up and have a bit of a problem, or not if I am an idiot.
        I have connected it all up on the bench and the motor works fine. However, there is only about 60 degrees of movement on the servos, 30 degrees in each direction. Any of you have any idea as to the cause of this and how to rectify it??
        Edited By lnvibleman on 05/02/2013 18:40:27
        Edited By lnvibleman on 05/02/2013 18:40:41
        #39055
        The Long Build
          @thelongbuild
          What is the TX set, as some set can be set to reduce the turn.
          #39056
          lnvisibleman
            @lnvisibleman
            It'a flysky unfortunately !!
            #39057
              Do the instructions with the TX mention how to change servo 'throw'?
              lnvisibleman
                @lnvisibleman
                They probably do but I don't have them.
                I'd guess they were in Chinese anyway so I doubt it would help .
                #39059
                Mike Pendlebury
                  @mikependlebury45959
                  You can download the manuals in pdf format at this site:
                  Just chose the model number on your transmitter.
                  They are in English as well as Chinese.
                  Mike
                  #39060
                  lnvisibleman
                    @lnvisibleman
                    Thanks Mike, done that.
                    What exactly am I looking for in the manual?
                    I really am very new to this mularky !
                    #39061
                    Mike Pendlebury
                      You are looking to see if there is a section that allows you to set the "end point" for the servo. This controls the amount of servo travel.
                      Assuming the physical stops inside the gear train of the servo allow it, then many of them can be set to swing up to nearly 180 degrees total travel.
                      Mike
                      #39062
                      lnvisibleman
                        @lnvisibleman
                        Ok, there is nothing even remotely like that in the manual. It just tells me how to connect it up and even I am not that stupid (?????)
                        #39068
                          What is the type and serial of the servos and did they come with the purchase?
                          lnvisibleman
                            @lnvisibleman
                            Hi Paul. The servos are HOBBYKING type HK15138 and were purchased newfrom a different source to the TX & RX
                            #39070
                              From the limited information that I have seen the HK15138 technical details specify 60deg of travel so without further information the conclusion is that your equipment is working correctly.
                              Spec as follows.
                              HK15138 Standard Analog Servo
                              Spec.
                              Torque: 3.8kg @ 4.8v, 4.3kg @ 6v
                              Weight: 38g
                              Speed: 0.21 / 60deg @4.8v, 0.17 / 60deg @ 6v
                              Voltage:4.8v~6v
                              Plug: JR Style
                              I hope this helps solve your problem.
                                Having thought further I realise that whilst answering your question I haven't helped solve the problem so I suggest that there are three courses of action available to you.
                                1/ Open the servos and change the internals to suit your requirements (difficult)
                                2/ Change the servos for equipment that has the necessary amount of travel.
                                3/ Use gears or linkages to increase the operational range of the existing servos.
                                lnvisibleman
                                  @lnvisibleman
                                  Thanks for that ! I have been looking at specs for loads of servos and I seem unable to find info on rotational range of each type. Is this available or do I just take my chances and hope that replacements will be OK ?
                                  Is there any possibility that the TX/RX can have any effect on the rotation?
                                  I ask simply because the same servos, when used with a freinds TX/RX, have a slightly greater rotation.
                                  #39078
                                    If it's going to work a rudder, 60degrees is probably just fine, as long as tiller and servo arm are the same length. If using a single rod to connect them and 30degrees each side is not enough, the relative lengths can always be tweaked a bit.
                                    #39080
                                      You would rarely need more than 30 degrees on a conventional rudder, any more and it just creates drag.
                                      If you do need more rotation have a look at ACTion Electronics' Servomorph which extends the throw of servos: **LINK**
                                      lnvisibleman
                                        @lnvisibleman
                                        The truth is, I was looking for more movement to operate the reversing and speed control on a steam engine,
                                        #39087
                                        lnvisibleman
                                          @lnvisibleman
                                          To obtain full speed in both forward and reverse, I will need at least 60 degrees movement from centre
                                          #39089
                                            You can use gears or mechanical multipliers to increase the range of a servo.
                                            #39093
                                              The ACTion unit mentioned above is intended for that sort of situation but, a Paul says, you can do the same thing mechanically.
                                              lnvisibleman
                                                @lnvisibleman
                                                Posted by Colin Bishop, Website Editor on 06/02/2013 10:40:13:
                                                This looks like a better solution than cogs and levers, even for a Luddite like me.
                                                #39114
                                                  If its just length of throw rather than angle covered, a longer servo arm will give the length. The only thing to watch out for then is to avoid the chance of toggling over and latching up which can happen when the end being worked on geys to the end of its "pull", and gets latched over.
                                                  A spung quadrant (or part of pulley), spring return and flexible cable is probably a better answer. Have a look at a car throttle cabe for inspiration.
                                                  #39150
                                                  lnvisibleman
                                                    @lnvisibleman
                                                    THANKS EVERYONE !
                                                    i think I have all I need to know on this one. If I have any further problem, i'll just ask.
                                                    #40044
                                                    Tony Bell 2
                                                      @tonybell2
                                                      The cause of the problem is your new receiver outputs a smaller signal width than your existing Rx. You will find no data on this. Using a servo stretcher is the only solution. It's quicker than trying to alter any rudder linkage.
                                                      For a full explination read my "Before Buying" **LINK**
                                                      Tony
