Powerperm motors
Powerperm motors
Home › Forums › R/C & Accessories › Powerperm motors
  • #49768
    Alan Hammond 2
      @alanhammond2
      I am not exactly new to this hobby but tend to be a lone modeller and build other things than boats. I have however just acquired a brand new Krick Sirius from the bay for the princely sum of £90 for a winter project and with a view to sailing it at a local club next year. A quick look through the instructions and I find that the recommended motor is a Powerperm with a 1 to 6 gear. Now the name Powerperm is familiar from somewhere but a search on the net has not thrown up any leads. Does anybody know of this firm or their equivalent. If not a suitable motor and battery set up for this model. Any help welcome.
      #5307
      Alan Hammond 2
        @alanhammond2
        Motor query
        #49769
          Alan
          Is there a prop supplied with the kit or specified on the plan? If so what size (diameter x no of blades) is it? MFA do a 6:1 geared motor but you might prefer to use a larger, direct-drive motor (gears are very noisy).
            6:1 is a very high degree of reduction although Dave has done a drawing for it here: **LINK**. This German site seems to be suggesting a 550 type motor which would seem about right for the size of the model and its type but you will need to translate it! **LINK**
            Alan Hammond 2
              @alanhammond2
              Thanks for the replies. The prop is still in its sealed bag so I have not had a chance to measure it but it looks to be about half an inch in diameter. It is also a real prop made from some form of plastic with a brass insert and not the rubbishy white metal effort supplied with a lot of models. The model itself is about 900mm long with a 330mm beam and so is reasonably substantial. I have done a bit more research and have a feeling that Powerperm may have been sold in this country as Decaperm.
              #49775
                I doubt very much if it is just half an inch, Alan. That's about the same size as my thumbnail and wouldn't power a model a fifth of the size. Decaperms were made by a German company called Marx-Luder and were the bee's knees about thirty years ago, but they are noisy and expensive compared with what's available these days. I would suggest a 775 motor from Component Shop, running a 50mm – 55mm 4-blade prop with no gearbox on 12 volts. **LINK** The MFA 6:1 motor would be, on reflection, a bit too slow with a prop of that size.
                Alan Hammond 2
                  @alanhammond2
                  I have just done a quick measurement through the packaging and the prop is three bladed and about 2" in diameter with a 4mm prop shaft. So what I will need is a nice big torquey motor either with a reduction gear or without. Which should be easy and cheap enough to find.
                  I can well believe though that Powerperm and Decaperm are one and the same as this is a German manufactured kit and probably originates from about ten or fifteen years ago. It is still available from the main mail order firms at anything from £415 to £460. So I am well pleased with it.
                  #49780
                    Alan
                    Either the 555 or 775 motors will do the job on 12 volts. £90 for that kit was a steal – I'm envious!
                    Alan Hammond 2
                      @alanhammond2
                      Odd one really. I just left a speculative bid of £100 on it before I went away for a few days expecting to be well outbid. Came back and nobody else had bid on it so I got it for the starting price. The same firm also had a Caldercraft Northlight kit up for sale at the same time. That went for £166 which was a good buy as well.. I suspect that the kits are old stock and the company which is a marine chandler was just getting rid of them.
