My battery is 12 volt, 12 AH. ESC is 20 amp Mtroniks marine. Motor is MFAComo 500 with 2.5:1 gearing. Running great.
My radio receiver is a futaba 7 channel.
I got a cooling fan running off the BEC for the ESC and another cooling fan running off the BEC as well for the motor. Also got 7 lights plugged into a switch, likewise running off the BEC. So all these accessories are plugged into the receiver, receiving 5 volts from the receiver. The ESC and motor get 12 volts from the battery.
When I turn the lights on, they are bright, but then a few seconds later they start to dim and fliker a little and the fan speeds drop dramatically. But if I unplug the cooling fan I’m using for the motor, the lights will stay on steady & bright, and the ESC fan will stay at full throttle.
This leads me to think I’m drawing too much power from the BEC. I dont’ really want to use a separate battery source for the fans because I really need to keep the weight on my boat as little as possible.
Is there any way to solve this problem?
