overweight fairmile
overweight fairmile
Home › Forums › All things floating › overweight fairmile
  • #41897
    steve h
      @steveh76883
      Hello all, got a weight problem with the fairmile, I put her in the test tank yesterday and shes an inch over the waterline!!. Spent rest of the day drilling lightening holes in everything. I managed to lose nearly a pound in weight ,but its not enough.Only solution is to change the batteries from the two 6v gel cels to nimhs. Any ideas would be greatly appreciated. steve.
      #4003
      steve h
        @steveh76883
        #41898
          You have already identified the solution – you will need to change the gel cells to NiMH. Component Shop have a good,reasonably priced range. LiPo cells would be even lighter but will need a more expensive charger.
          Component Shop list weights for their battery packs. So if you remove the gel cells and ballast the model down to the correct waterline, the weight of the ballast will tell you how much weight you can allocate to the new batteries.
          Edited By Colin Bishop, Website Editor on 27/06/2013 22:49:35
          #41901
            Steve
            Going for a lighter battery pack and drilling holes in the frame are the primary ways of reducing hull weight.
            Take care that these weight reductions don't change the boats centre of gravity by making the model top heavy.
            steve h
              @steveh76883
              Thanks guys. I looked at the nimh cells at component shop, cant decide , the D cell packs, 7.2v 9000mah x 2 , or four 7.2v 5000 c cell packs. similar price, similar weight. Im using four johnson 600 motors. dont know what the run time will be.? Help. steve.
              #41912
                The weight needed to get down to the correct waterline will be the deciding factor, just get as many amp hours you can for that. Run time is essentially a separate issue and will depend on your motor/prop combinations. If you run the boat in the bath with your existing gel cells (useful for testing as per my other post!) you can measure the amps drawn at different throttle settings. The current drawn when the boat is tethered in the bath will be slightly higher than when running free on the pond at the same throttle setting.
                Comparing the amps drawn at full throttle with the capacity of your batteries will give a rough idea of the run time at full speed but of course on the pond a model boat spends quite a bit of its time throttled back or stopped which will extend your 'time on the water' time!
                steve h
                  @steveh76883
                  Cheers Colin. ill probably go for the two 9000 packs, theyre the highest capacity ive found and they save 4 pounds in weight, if thats not enough weight off then ill take the deck off and do some more drilling!!…. she wont go in the bath, too big, had to build a tank in the garden. steve.
