Need a 4BA prop
Need a 4BA prop
Home Forums All things floating Need a 4BA prop
  • #78677
    Martin Field 1
      @martinfield1
      Hi, has anyone got a 4BA thread prop in 2 or 3 blades of around 30-35mm diameter for my Chris Craft. I bought an old Sea Hornet on ebay cheap and have turned it into a Chris Craft Special racer with a new deck and hatches. I have now painted it as the rare blue and white scheme and went to check the shaft, only to find that it's 4BA threaded. I can't move it as it's very much part of the hull. I guess I must have been assuming it was M4, but no. 3.5mm diameter shaft with a 4BA thread each end.
      If you happen to have a 4BA joint that would be good also.
      Cheers,
      Martin
      #4522
      Martin Field 1
        @martinfield1
        #78684
        David Marks 2
          @davidmarks2
          Martin – There is a possible engineering solution to this problem. You will nee access to a small lathe or know someone that has. Also assuming that the inner prop shaft can be removed from the outer. This will allow you to use a M4 prop on the existing (but adapted) shaft.
          Prop End – Obtain a stainless M4 screw of suitable length, remove the head and drill 2.8 mm which is just below the core/minor diameter of the thread. Turn down the 4BA thread on the end of the shaft so that it is a snug fit inside the 2.8 drilled hole. The two can be held together with a minute dab of Cyno e.g. Hafix or similar.
          Coupling End – Assuming that you will be using a Huco Coupling (or similar). The inserts for these are available in a number of sizes ( but probably not 4BA), but find one that will allow you to drill & tap 4BA.
          #78691
          Martin Field 1
            @martinfield1
            David,
            I was thinking along those lines myself. I will have to get a 4BA tap and then drill out the prop and make a thread reducer sleeve, or, as you suggest, a thread increaser to M4. I have 2.5mm drills, or 2.4 (3/32&quot ,but no 2.8.
            I'll see what Huco do, but I tend to make my own couplings anyway.
            Cheers,
            Martin
            #78695
            David Marks 2
              @davidmarks2
              Martin
              Thanks for the response. Anything in the Taps, Drills, Dies category, then I use Tracy Tools in Torquay.
              Martin Field 1
                @martinfield1
                David, yes I bought my centre drills from Tracy and a few odd bits and bobs. i tend to use ebay when I can as my wife has it on her machine and does all the Paypal stuff that I don't understand.
                Cheers,
                Martin
                #78699
                Charles Oates
                  @charlesoates31738
                  Or you could remove the shaft, and replace the bushes in the tube to use an M4 shaft. Easy fix for a long term solution. Assuming the bushes can be removed, which is usually easy.
                  Chas
                  #78709
                  Trevor Drabble 1
                    @trevordrabble1
                    Martin , Suggest you talk with Simon of Prop Shop . Trevor .
                    #78714
                    Martin Field 1
                      @martinfield1
                      Bushes won't move Charles. I had considered that, but also there isn't room inside the tube for a 4mm shaft.
                      Trevor, does the Prop Shop sell a variety of threads? Haven't bought a prop from them since I bought a left and right hand pair for my last Riva scratchbuild.
                      Martin
                      #78716
                      Trevor Drabble 1
                        @trevordrabble1
                        Martin , Last time I spoke with Simon at the Mobile Marine Models open day he said he taps props to customer requirements . Trevor .
                        #78726
                        Martin Field 1
                          @martinfield1
                          In that case, I'll give him a shout. Many thanks.
                          Martin
