Hi Campbell. The two obvious things to do are 1) shift battery 2) use larger battery (9.6V) and 3) change props to 35mm (ok, that's three things!)
30mm is quite small, and a shift to 35mm should be within the motor capability. Two blade props are available in X (course) potch, and S (`normal`) pitch. As they are very cheap, worth buying a selection. Using a wattmeter is also good. Has been suggested many times before..they are very cheap and will show you if the motor is being overloaded.
Going to a 2s Lipo will increase performance without any other changes due to their capability of delivering more current whilst maintaining voltage and being half the weight. A fully charged one will be over 8V in any case, this alone giving more revs.
Ultimately you could fit a gazillion watt brushless motor. HOWEVER please look at the motor specs first. A 600 of your type might produce 60 watts or so (correct me if wildly out), but swapping these for an 800 watt brushless……..
Brushed motors are very gutless in comparison size for size with brushless, however not all brushless motors are equal, and similar size, turn and KV specs can produce a wide range of power. The weight saving alone may be worth it, but bear in mind two motors need two ESC. As you are looking for a relatively small increase on performance, then work out roughly how much power your 600 makes and then find a brushless of a slightly higher power, but nothing with too high a Kv rating 1100-1600 seems to be a happy medium.
Edited By ashley needham on 22/10/2018 09:16:44
