Good Morning Walter
When I fitted 3 motors to my MTB I used 2 speed controllers, 1 for the center motor and 1 for the 2 wing motors.
When in the water I used the center motor for chugging around the lake but when I needed the speed I would use the 2 wing motors as well.
The central prop was slightly larger than those on the wings which, as stated by everybody else, are left / right handed.
Ken is right about fixing the props to the shafts especially on larger high speed models I have bitter experience of loosing very expensive props even with the lock nut firmly fixed in place.
I found that I had to have all 3 rudders working as on just 1 rudder the boat just continued on in a fairly straight line.
