I have just fried an Mtroniks Micro Marine Viper 10 during out of water testing on my Amati Titanic hull. Before frying the other one, I would appreciate advice on whether the set-up is appropriate.
The motors are MFA 280 brushed 12-24 volt, current 0.3 amp at max efficiency. I plan to use 3 bladed 30mm diameter brass props, closest to the scale size of 28mm, although I could downsize to 25mm. Batteries are two 6 volt, 1 amp hour, SLA's wired in series.
The Mtronics mixer was connected as follows. Input 1 to terminal 4 of the Planet T5 receiver. Input 2 to terminal 1. Outputs 1 and 2 to the two ESC's and output 3 to the servo. Output 4 was left blank. The red wire to the receiver was cut on one of the ESC's to avoid both trying to power the receiver.
What confuses me even more is that, on my Riva model which does not use a mixer, the ESc's are connected to terminal 1 (not terminal 4) and this works. Trying this on the Titanic does not work.
The Titanic set-up seemed to run OK forward or reverse, although the ESC's did get hot. Rudder left resulted in the relative motor speeds changing as needed. Rudder right seemed to stop both. I think the thermal overloads cut in more than once, making the red light on the receiver flash which would normally only happen if it is not bound with the transmitter (Planet T5 mode 1).
I chose the micro ESC's because they are small (23g) and should handle 10 amps. I could fit the larger 15 or 20 amp units, both of which weigh 55 gms. Before I go any further, am I making some fundamental error?
Sorry to be so long winded, but I though it better to supply all relevant information and I do need help!
Jeremy
