Motor for Zwarte Zee
Home Forums R/C & Accessories Motor for Zwarte Zee
  • #59748
    Southern Sailor
      @southernsailor76583
      Good day all. I am starting on the Billings tug Zwarte Zee soon. Any suggestions for a suitable motor? Thanks. Brian.
      #5383
      Southern Sailor
        #59749
          Brian
          For direct drive with a prop of around 40-45mm dia one of these should do the job on 12 volts **LINK**
          If you want more torque then I'd suggest one of these **LINK**
          Kev.W
            @kev-w
            If you need serious power, take a look at ……
            Mark Jarvis 2
              @markjarvis2
              Hi Southern sailor
              I have the second type of motor in mine. Kip's idea is not good due to weight, the motor is brilliant, i have the 24v in my Amsterdam, but for Zwart Zee you dont have the dispacment in the hull
              Hope this helps
              Mark
              #59756
              Southern Sailor
                Thanks people. I must admit that the model looks very short of freeboard in the stern area so I would be wary of adding too much weight. I was wondering about the T4A by Mobile Marine Models. Would that be too light? Otherwise Dave's suggestions could be the answer. Brian
                #59758
                  T4A would be fine – it's quite small and light.
                  Southern Sailor
                    The T4a is a very nice motor and seeing I have two from a trip to UK some years back, I was wondering about using two T4a's driving one shaft. I have the facilities to make a gearbox to do that. Can anyone point me to belt drives and their design. Are there commercial belt drive systems (i would prefer belt to gears as they are not as noisy) for models that could be incorporated into such a gearbox.
                    Also, is it practical to couple two motors to one shaft? If one goes slightly faster that the other it would be using power to overcome the difference. Antone got any advice on this? Thanks and cheers for now. Brian
                    #59851
                      Why would you want to? If you're unhappy about the power of a T4 being adequate then fit a larger single motor. Despite apparently successful experiment in this area I'm far from convinced that there are any practical advantages to this and still several electrical issues which could crop up. Unless you're the type that wants to climb mountains just because they're there then my advice would be to keep things simple.
                      Southern Sailor
                        Point taken Dave. I have two T4s and it would have been an alternative (a cheaper alternative) to getting another motor from UK. Cheers for now. Brian
                        #59855
                        Charles Oates
                          @charlesoates31738
                          Hi Brian, It’s a long time since I built a Zwarte Zee, but I do remember that mine was overpowered with a decaperm on 6 volts. I ran well throtled back most of the time.
                          Why not just stick the T 4 in and try it? It’s a good motor. If you’re happy, fine, if not move on to another motor. Nothing lost, experience gained.
                          It’s how I’ve learned, and continue to.
                          Chas
                          #59856
                          Charles Oates
                            @charlesoates31738
                            Ps Brian, I mucked around wuth 2 motors on 1 shaft many years ago, don’t go there, lots more amps, bu…r all difference.
                            T4, if you have some props, start with the 40 and see how you go.
                            #59858
                            Southern Sailor
                              Thanks Charles. That seems to be the general consensus, and I will go with that. Regards. Brian
