Hi Jason,
I’ve just looked at the build manual for this part of the boat. I can’t remember cutting off that ammount – probably because i cut a new deck out anyway. The manual clearly states 188mm and 202mm to the centre of each frame, which mine are. Note though the 202mm is not measured from the centre line.
As part 28 glues directly to the aft frame with parts 25,27 and 24,26 attaching to this and finally part P312 sitting accross the centreline of the forward frame spanning part 24, 25 you can be assured that the resulting hole in the middle will be correct.
Parts 73, 74 glue onto parts 25,27and 24,26 and form the shape of the deck.
Because the forward deck slopes front to rear and inboard to outboard this will clearly mean the deck is oversized. I do remember the aft deck being 4-5mm too big, i think to allow for slight deviations in step positions.
I think i came to the conclusion that as long as the two measurements were correct it would stand to reason that the superstructure would sit over it ok. Having completed that section and now on the superstructure build i have not encountered any other problems with parts 25,27 and 24,26.
This is one of many instructions you will question on this kit build.
i hope that this goes some way to helping you with your problem. Happy building
Mark
