Posted by Chrissy J on 27/09/2017 17:13:08:
Hello everyone!
I have in my hot little hands, an eBay special: a 40Mhz 3-channel radio set, with four crystals, a gift from my partner. Through dint of close examination, I've found that two are marked 40.975 and the others 40.725.
Am I right in thinking that I need to use matching-numbered crystals, as I recall doing so with 27Mhz a long time (1988) ago?
Um. You are correct that you need 'matching' crystals for the band you are working on. But I would usually expect the Tx and the Rx crystal to have a slight offset, due to something called the 'intermediate frequency'. That used to require a 455Hz difference in the old AM days (except for McGregor, who used 470!). That's why you can't swap a Tx and and Rx crystal, and why they are marked that way.
What is the kit you have got? And what is marked on the crystals? Incidentally, I don't expect there would be any damage caused by trying them out – if they don't work they just won't work. But if we can find out what the frequencies OUGHT to be we will be in a much better position…
This link might help… https://www.rcgroups.com/forums/showthread.php?808548-How-do-you-identify-modulation-mhz-and-frequency
P.S
Having looked at the other messages here, I see we are talking about a Hitec Ranger set. It looks like Hitec crystals are readily available, and, looking at the shops, I see that they seem to print the channel frequency on BOTH the crystals, rather than the actual frequency each works at. See here, for instance – https://www.modelhelicopters.co.uk/electronics/crystals/hitec.html
That's a bit confusing if you are trying to follow first principles! However, it seems likely that you have a pair of channel 975 and a pair of channel 725 crystals – now all you have to do is find out which one of each pair is the Tx and the Rx crystal, which you can do by trial and error. Unless there is another marking or some kind of indication…
Edited By Dodgy Geezer on 27/09/2017 21:46:06
