Hi Ashley,you can tell a torquy brushless from a high speed brussless by the kv.
KV is RPM per volt
A high torque motor are low rpm and in most cases are outrunners EG: 400KV to 1,700KV
A high speed motor are high rpm amd in most cases are inrunners EG: 1,700KV to 5,000KV
so in conclusion if you are running 12 volts and you have a brussless motor with a kv value of 600kv
you then times 600×12=7,200rpm,but then if you have a motor with a kv value of 5,000.then it would be 5000×12=60,000 rpm
hope this is of some help
kind regards
Alan
