LCT Front Ramp
LCT Front Ramp
Home › Forums › All things floating › LCT Front Ramp
  • #97337
    Silverfern Downunder
      @silverferndownunder
      Hi to everyone reading this new tread.
      I am building a commercil Landing Barge and starting to work on the front ramp. I have created a photo album for you to review and get a better understanding of what I'm building.
      I have a Hitec HS-785HB sail winch to use for attaching cables to to lift and lower the ramp.
      Now how to make it all work using my Futaba T6EX controller and Action electronic components?
      All suggestions will be much appreciated.
      Thank you kindly, Robert
      #4757
        #97338
          Robert.
          A sail winch servo is just a servo, and plugs into the receiver as per a normal servo…this is my understanding although I am not a sailing man. The question is what sort of servo do you have as I understand there are different sorts of sail winch types.
          Which A E components do you have?
            A HS-785HB is just an ordinary servo with more travel. Instead of 90 degrees of travel, it does 1260 degrees (3 1/2 turns) with a typical transmitter on a proportional channel. Depending on the particular transmitter.
            Plug it into a switched channel and see how many turns you get between one switch position and the other. Once you know that plus knowing the diameter of the drum, you know the travel available. After that, its just a case of working out the best arrangements for the string, matching the travel you have with the travel required for raising and lowering the ramp. And stopping when you get there. With a 1" diameter drum, thats about 11" of travel, but the settings on the switched channel might be different.
            #97340
              You might also want to consider including some form of flexible arrangement when closing a door with a sail winch. If you have not got the arrangement absolutely perfectly adjusted when the door closes you may end up with a slight gap or worse, over tightening of the arrangement and damage to the model.
              Simply including a light spring or even a section of elastic in the arrangement will enable firm closing without over tensioning the closing mechanism. I have seen a simple light spring used in the past to very good effect.
