I drew up my own plan, based on a drawing on the Internet, studying photos on the internet. Then the project stalled, partly not being clear where the CG should be. Then I had and have drive line issues, wanting to use a flexi drive shaft.
More recently I decided that the CG needs to be pretty far back.
The initial thoughts were using a (I think) 7 cell Sanyo Nicad, using a 480 motor.
My present thoughts are a Inrunner using a Lipo. I probably now would now use a solid shaft, at a shallow angle. With the passage of time I am thinking of about, 150-200 watt motor. I now need to identify the most useful KV.
Finishing is the most problematical set of issues now.
In a way the book did help in understanding a little of what was intended.
With respect to Bluebird, it is evident that the forward 3 pointer is not the only concept. As the Spirit of Australia is not apparently a 3 pointer of the Bluebird or Crusader type.
As for scaling speed, dimensionless analysis is often used to provide a pointer. I have no idea as to what is an appropriate set. What is certain is that the Froude relationship is not the one. As it really tells you a long hull narrow beam provides the highest speed for a set power input, for a displacement hull. |Mentioned in the book, much to the disappear of Railton.
