Hull construction in fiberglass
Home › Forums › Beginners › Hull construction in fiberglass
  • #12680
    Anony Moose
      @anonymoose37736
      Firstly I have just joined and wish to say a big hello and thank you for reading my post. I have been searching for detailed information on how the fiberglass model hulls are constructed with no joy (on this site that is .. so if i’m missing something fundamental and this question is asked daily ..sorry !!)..i wish to make my own one off type original design…I have a little experience with fiberglass and even gelcoat but how to make the mold part baffles me? and probably a million other things i have not even thought of yet that you probably all wear T shirts for..any assistance you can offer would be greatly appreciated
      #12682
        Hello Anony
        And a very warm welcome to the site.
        The question that you have asked is not uncommon and a few of us have constructed our own hulls out of fiberglass so I would expect that you will have all of your questions answered.
        To make a mould you must first produce a "plug" which is an exact size and detailed version of whatever you wish to build, in the case of a boat hull you can make the plug out of wood, plaster or use the hull of an existing model.
        The surface of the plug must be perfectly flat, smooth, even, grease free and clean as every blemish will be picked up on the mold and subsiquent casting.
        Once you are happy that the plug is ready then you can begin to cast the mold over the top of the plug by first applying a release agent then gel coat and finally the matting.
        When set you will have an "inside out hull" with the smooth side on the interior. This is your mold.
        I have over simplified the process as it is frought with problem concerning air temp, humidity, mixing and setting times……………….and so on.
        There are some very good books on the subject and I would suggest that you visit your local libiary to check some out.
        Hope this is of some help
        Sorry for the spelling but the checker is not working
        Anony Moose
          @anonymoose37736
          How to do?
