How to keep brass Shiny?
Home › Forums › Beginners › How to keep brass Shiny?
  • #117454
    Mairtin Coss
      @mairtincoss26184
      Just about to start Amati Dorade. Lots of shiny brass fittings, and photo etch parts, which was big attraction of the kit.
      Is there a method of treating all these parts to keep them in the new condition, to prevent patina etc.
      A bath solution would be best as some are very small.
      I see rustins do a lacquer- is that good?
      #117460
        You can paint it with just about any clear varnish but the trouble is you want the surface to be nice and shiny first, so consequently the varnish has nothing to key to and so tends to easily chip and scratch.  A lot of varnishes tend to discolour with time, which tends to be a little bit more noticeable when over polished brass than it is over wood and the surface does dull with age.  Plus you have also burned your bridges, so to speak, as when the varnish chips and water gets underneath,  or when the varnish dulls or discolours you have to strip the varnish off before you can repolish the brass, which is a real pain.  Consequently the brass never looks quite as good as you want it to.
        I know its not what you want to hear but the best way to treat brass is to polish it and then simply re-polish it as and when it needs it.  This has the added advantage of developing a lovely patina over time and the brass will actually take very little to recover the shine one it has been originally polished.
        #122567
        cheddar24man
          @cheddar24man
          Thoroughly wash them in HOT water, dry and coat with a clear varnish.
          #122570
            I fear Richard is right. Clear lacquer will preserve most of the shininess temporarily but eventually degrades as it has nothing to bond to. Same thing happens full size, you just have to keep polishing after a while as per the Victorian Navy!
            Similar with copper, looks lovely when first installed but rapidly oxidises to a green patina. Which is why copper roofs are green!
            For models you can get metallic paints to preserve the original effect although some are better than others. Chrome is always tricky.
