As usual Paul cuts to the bone the vexing subject of ballast.
The bath wins in my opinion. Not only do you get to see how much actual weight you need to get the vessel to the waterline, but also WHERE to put this weight, although a wobble test is v useful for determining stability and so on for which the bath may be a bit small. I know Kimo has one of those Imperial Leather advert baths, you know, the sort you walk into and so he does not have this problem.. hang on, no, I am getting this mixed up with leaked pictures of DM`s new workshop area.
Some leeway needs to be allowed, in my experience, for trim changes when on the move. My little HMS Devastation (I wish I hade built a larger one) has significant nose up static trim, due to the upwards levering forces of the twin props DESPITE that the shafts are almost horizontal, perplexing this. This then gives a nice even keel when moving at battle speeds (or a bit more perhaps).
A recently built model had to have so much ballast added I actually ran of available space available to put the ballast (on its initial bath test) and I had to redesign the interior and ditch some equipment then purchase sheet lead as this would take up less room than my bits of squashed pipe….
