A removable internal weight is likely to be even more trouble than a fixed one. Yes a big heavy boat can be very awkward to handle in and out of a car, but having access through the deck at the poolside can be even worse. It will still need transferring into and out of the water fully laden, it isn't the kind of thing that can be added with the boat floating.
Bagged shot of various sizes to get good packing density in the right place, covered with a layer of fibreglass to keep it there. The FG layer only needs to be strong enough to hold the bags in place should the hull be inverted, shot that has had resin poured into it eventually becomes a PITA. A layer of FG that can be attacked with a dremmel later keeps options open.
One thing about the Atlantis – it was a big model with lots of possible extras that all added more weight upstairs, where you really don't want it, so one without the optional exras, should have some leeway as regards ballasting.
Edited By Malcolm Frary on 16/02/2019 11:43:37
