Glue
Glue
Home › Forums › Scratch build › Glue
  • #12231
    John Platt
      @johnplatt24069
      Hi guys.
      I have built a scratch built model of a 1960’s ship.
      The main hull is built from wood and filler.
      I now wish to cover the hull with a plastic material which will have all the original rivets etc.
       So, the question is….. What glue can I use to bond these two materials together giving me about 3 minutes manipulation time and that will be 100% water proof?
      Curing time is not important.
      Thank you for your thoughts.
      John.
      PS. I built the first model submarine that submerged and fired torpedoes under radio control in the 1970’s. I got several free holidays at Bream Sands from MAP and could tell you many funny stories about other models that sank.
      #12232
      Manxman
        @manxman
        Hi John,
        You do not mention which type of plastic material you are going to use, so have a look at the Model Tug Forum – http://modeltugforum.com/index.php?topic=181.0 – I have a chart here listing various glues.  I can not take the credit for the list, but I picked this up from another site a while back and can not remember the original site – my apologies to the original author.
        Hope its of some help – Ken
        #12234
        John Platt
          @johnplatt24069
          Hi Ken.
           Thank you for your reply.
          I visited the list you suggested but it didn’t quite answer my needs.
          The type of plastic has not been decided yet. It must be pretty thin (0.5 mm?), be able to take a model rivet punch impression without breaking the surface and be readily able to be stuck to the wood when I have found the correct glue.
           Thank you once again.
          John.
          #12267
          mick
            @mick
            hiya john mick here
            look under   plastidip.co.uk this might help your problem  they have some amazeing
            stuff hope this helps you
            #12274
            Telstar
              @telstar
              Hi John
              This question was raised on a different forum, For covering wooden superstructure with plasticard. One reply there was the use of double sided tape. apparently in the motor trade badges and trim is fitted to bodywork useing double sided, it  is strong and weatherproof.
              Cheers Tom
              #12283
              Paul Freshney
                @paulfreshney24971
                Experimentation might be advisable. I have used superglue successfully, but you only have moments to get it right. Evo-Stick also works, but again zero manipulation time. How about the glue that aeromodellers use for gluing clear canopies in place?
                #12291
                Manxman
                  @manxman
                  The canopy glue mentioned by Paul is "Formula 560" made by Pacer Technology – available from almost all model shops – this is white when applied but dries clear.
                  Ken
                  #6427
                  John Platt
                    @johnplatt24069
                    Which glue
