Hi Robin, Colin,
Thanks for you helpful advice.
I have got a bit more info.
The 2 x ESCs are actually rated at 50A forward or 20A backward.
Thr Graupner 700BB s have a nominal 12V Voltage, drain at max efficiency 12.5A and stall current of approx 43A.
There are two independent banks of 8 x D cells
I had in mind one fuse of 10A in each circuit (to be installed near the battery as advised), but I think 15A may be better. This is well below the 40A which is probably the recommended max. Would this be OK.
Test idling on 6V the motors were humming along using 1.2A and I could still feel the power of these motors.
I have updated the photos in the album.
Haig
