french fishing boat
french fishing boat
Home Forums Scratch build french fishing boat
  • #36034
    steven smith 6
      @stevensmith6
      I have just got the plans for this model 1/10th fishing boat, has anyone built this before, as this is only my second ship, and first from a plan any help will be great.
      I am going to build the keel out of beech, but I am wondering if this timber is too hard, is there a better timber? I will give myself a good 18 months on this one!
      #6817
      steven smith 6
        @stevensmith6
        Louis Helloise Bautier
        #36035
          Hello Steven
          This could be your lucky day!…….I built the Louis Heloise, way back in 1999 and have lots of pictures in my gallery
          It is a great builders model, very bulky, scale construction and can be filled with masses of fine detail
          I fitted a built in motor, which is a nice feature to have and helps with the sailing on quiet days
          LH page 23
          #36038
            LH page 17
            One of the nice features of the build, is that it is built plank on frame……The right way up on it's stand
              Bob..what about the main question.. the use of beech?????
              (nice boat, by the way)
                It's up to the builder, what wood he uses, but Beech will be hard work
                I used Mahogany for the frame and Obechi for the planking, because I had it in stock, but Obechi is funny stuff, it's a bit like Balsa and hairy with it!
                I think Pine would be ok, you just have to work round the knots
                  LH Page 30
                  #36059
                  steven smith 6
                    @stevensmith6
                    Cheers Bob.
                    I like lots of help, and good pics, especially the transom end, as I can't fully understand how it is constructed, the plan is a little vague i places for the beginner.
                    looking at the frames, they seem to have more cut out of them than they should have, at the keel.
                    At present I am looking a the plan, deciding the best way to attack it, I've worked out the keel shape.
                    I'm going to joint the stem and rudder post to the keel mortice and tennon, I think that will be stronger construction, and just glue the deadwood and transom spider, I'm going to rout out the keel from a solid bit of timber, rather than make a box section,
                    I would like to use teak but can't find a good supplyer, I agree beech is well hard.
                    I have started to cut out the sections out of ply, and will make the keel when I find the right timber!
                    Cheers guys..
                    #36060
                      One important feature missing off the hull frames, is a temporary top bar with central notch
                      This is essential for alignment
                      You could do with purchasing the four magazines in which the build was described, then the method of constuction will come more apparent
                        LH page 1
                        This was a very important stage in the construction!
                        I added temporary cross strips to the top of each frame and aligned the frames accurately
                        Note how the hull is built, the right way up……..Nice?
                        steven smith 6
                          @stevensmith6
                          Hi Bob.
                          Great stuff, do you know the magazines that the build was described in? I could do with seeing them.
                          Did you cut smaller slots in the frames, or did you cut them as plan?
                          I like the stand that you made I'll make one.
                          Steve
                          #36077
                            It is essential that you make a first class job of the keels, bowpost and transome
                            Make them very accurate and screw the pieces together……..Beech would be ideal for this section
                            This is a big project for a builder only having built one model previously!
                            I cut the frames slots as shown on the drawing…..Why do you ask?
                            This is the link to my LH album………. **LINK**
                            Haven`t got the magazines anymore…..Sorry
