ESC
ESC
Home Forums R/C & Accessories ESC
Viewing 21 posts - 1 through 21 (of 21 total)
  • #37478
    david the newbe
      @davidthenewbe
      hi all
      ive just been giving an ESC and it says on it dc input 2s – 3s lipo do i have to use lipo batterys or can i use any really
      thanks dave
      #5196
      david the newbe
        @davidthenewbe
        esc and battery
        #37479
        hobbiesruz
          @hobbiesruz
          Hi David… The esc should also state 5-12 NIMH… Wat batteries were you thinking of using..
          #37480
          david the newbe
            @davidthenewbe
            hi hobbiesruz
            and thanks for your reply no it dont say 5-12 nimh as that is the battery type i would like to use
            thanks dave
            #37482
            hobbiesruz
              @hobbiesruz
              Hi Dave..what make esc is it… Gary
              #37483
              hobbiesruz
                @hobbiesruz
                I think You can still use it the only thing is the cut off voltage is differant…
                #37485
                david the newbe
                  @davidthenewbe
                  its a joysway 20A water cooled brushlees esc
                  dave
                  #37486
                    David. Tricky, Tricky.
                    Most ESC (as far as I am aware) can be programmed to accept either battery types; OR be able to set the cutoff voltage to a higher value (so being more suitable for Nimh types) as Nimh dont mind being flattened,,unlike Lipo.
                    This means fiddling with the transmitter of purchasing a program card. This is best as it becomes easy then to program these things up.
                    Its not easy, you know…
                    david the newbe
                      @davidthenewbe
                      thanks ashley ill see if i can find a program card for it
                      dave
                      #37488
                      hobbiesruz
                        @hobbiesruz
                        Hi Dave… They don’t seem todo a program card..most esc detect what voltage is being connected to them. The cut off voltage is proberbly set between 2.8 & 3volts per cell for lipo on that esc… A NIMH pack should be fine to use. as nimhs U can discharge to 1volt per cell and still take a charge. The problem U might have is duration being less as cut off voltage being high… Also that esc will not take more than 12.6volts… Gary
                        #37489
                        david the newbe
                          @davidthenewbe
                          hi Gary
                          thanks for the info and as for the duration im not warried about that as i always have spare in my bag
                          thankyou again dave
                          #37499
                            It might also be the case that NiMH batteries might not be able to deliver the same current as lithium. Under heavy load, the voltage might dip below the cut-off voltage and cause spluttery running.
                            #37511
                              Dave what voltage Nimh are you using? Lipo in 2s form come in at 7.4V , so if the controller is set for Lipo operation, and you stick a 7.2V Nimh on it, it will see this as a slightly run down Lipo to start with !! I believe another forum member had this issue.
                              david the newbe
                                @davidthenewbe
                                im looking at useing a 8.4 nimh pack hopefully im going to put it to the test later today im the bath and see how long it lasts hopefully it dont go bang as its a water cooled esc but i dont have a boat to set that up but im looking at just some rubber pipe and cable tyes to hold all in place
                                dave
                                #37529
                                david the newbe
                                  @davidthenewbe
                                  hi all
                                  it worked ok for 30 mins but only 1 way it would not reverse but im not sure if brushless motors can be made to go 1 way as i was told the ESC is new
                                  dave
                                  #37531
                                  Diede van Abs
                                    @diedevanabs87670
                                    Brushless motors can run both ways, no problem. The problem is probably your ESC is a plane/heli one. Nice to use in speed boats (which you don't want to reverse anyways) but no good at all in scale models.
                                    Read the manual to see if it can be programmed for running both ways, it might just be that the thing is capable of it.
                                    #37534
                                    david the newbe
                                      @davidthenewbe
                                      no its not a plane or heli as its water cooled amd no manual with it as i was giving it by a mate who never whent brushless and he said it is new and never been used so maybe it was a bad 1
                                      dave
                                      #37559
                                      Diede van Abs
                                        @diedevanabs87670
                                        I searched the internet for the ESC – no real luck there, could not find the exact product and no manual either. What I did notice, is that Joysway seems to focus mainly on speedboats, so probably it's a speedboat ESC (which is essentially a plane ESC with watercooling…) so probably the bloody thing will not reverse.
                                        If you connect the ESC with your throttle stick in full down position, and you start feeding the throttle… Do you have the whole stick travel for forwards only? Or does it only start running after you move the stick through the center? If you seem to "miss" half of the stick travel, you might still have some luck and you need to search harder for a manual to program it correctly.
                                        If you can use the whole stick travel for forward only – tough luck to you, it's speedboat only.
                                        What you can do however, is use a relay which you put on a different channel, with which you swap two of the three wires of the motor (only do that when it's not running!). Swapping two wires makes the motor run the opposite direction. Might be a bit fiddly, but could be worth trying.
                                        Edited By Diede van Abs on 13/11/2012 22:03:46
                                        Edited By Diede van Abs on 13/11/2012 22:07:28
                                        #37562
                                        david the newbe
                                          @davidthenewbe
                                          hi Diede
                                          thank you for looking .
                                          it setsup with stick center and not like ones for planes where u have to move stick down to set it.
                                          im thinking maybr the reverse side has gone
                                          thanks for the advice i could have a boat with just forward like the swordsman im going to build
                                          thanks again dave
                                          #37563
                                            dave, Stick a big rudder on it right behind the prop with lots of throw and the lack of reverse will not be so bad !!
                                            Diede van Abs
                                              @diedevanabs87670
                                              Posted by david the newbe on 14/11/2012 07:25:52:
                                              Could be, however it is more likely that reverse is disabled or even that it's defaulting to braking. Maybe if you email Joysway (check http://www.joysway-hobby.com/Article_Show.asp?ArticleID=2) they can help you with a manual on how to set it up.
                                              Brushless ESC's reverse by means of the order in which they activate the motor windings, very unlike brushed ESC's which use a separate set of FET's for the reverse. That means, simply said, that a on a brushless ESC a broken reverse is very unlikely as forward should be broken, too.
