Think Ron Rees would be better at answering this question – believe his article on a multi purpose hull promoted the same method ?
As an aside there are various other things one can use with dope or thinned polyester resin rather than fibreglass as even the fibreglass mats are unpleasant to use. However there is one very thin tissue type fibreglass meant for use on walls to hide small cracks and surface blemishes – lighter than tissue itself . Bought some in UK about 15 years ago – easier to use than the others and provides a strong surface.
The alternatives are the tissue meant for waterproofing roofs , waterproof paper towels (the kind used as washing up cloths usually blue or green which end up quite heavy) and finally nappy liners meant for use with cloth nappies. Used all three with polyester resin thinned about 30% & dope with success . Produced strong hulls with balsa . Paper towels over cardboard were used on a full size Beach Buggy – reluctant to use them on small boats because of the weight.
Have also seen a lightweight cloth tissue in the drapers (thanks to better half) – meant for stiffening light cloth in dressmaking – never got around to testing it – may well work too . All of these are preferable to paper tissue as it tears far too easily when wet.
Never tried epoxy resin as it not easily available in SA – should imagine it would work with any of these over foam . Hard to get anything model boat related here – including the magazine……….
Edited By redpmg on 16/01/2021 09:55:31
