Calypso
Calypso
Home Forums All things floating Calypso
Viewing 25 posts - 1 through 25 (of 52 total)
  • #55015
    BRYAN ASTON
      @bryanaston57723
      Greetings all I have just bought a used Billings Calypso research ship and are finding it very hard to trim it ,are these model boats very unstable as seems to take a lot ballast to keep it upright. Has anyone any experience with this model.
      #4181
      BRYAN ASTON
        @bryanaston57723
        Ballast
        #55020
          Hi Bryan
          Never had the Calypso but have owned a few billings boats and have found that they all needed surprisingly large amounts of ballast to trim them correctly. My favourite form of ballast for billings boats is wheel balancing weights that I used to buy by the bucket full from scrapyards.
            I certainly do remember reading years ago that this particular model was very tender. It carries a lot of topweight. You might have to consider using a small detachable weighted keel for sailing the model.
            If you just put more ballast in then it won't float at the correct waterline.
            BRYAN ASTON
              @bryanaston57723
              Thank you colin and Paul for your suggestions to keep Calypso upright , when I don the waders and rescue my boat from the bottom of the pond I will follow your suggestions. When I can gain access to the club hut it should be no problem, it is only o.6 m deep, too cold to paddle.
              #55092
              Geoff Sleath
                @geoffsleath41411
                Posted by Colin Bishop, Website Editor on 11/01/2015 16:33:35:
                Surely if you put in enough ballast in the right place the boat can't help but float on waterline? The volume submerged displaces that volume of water which determines the overall weight of the boat (Archimedes principle). I can only assume the Billings kits are light which must be a good thing and make them more stable because more of the weight will be ballast below the waterline.
                I'm no expert beyond remembering a bit a school physics, possibly wrongly.
                Geoff
                #55095
                shipwright
                  @shipwright
                  Geoff,
                  The problem here is not overall weight but the vertical distribution of that weight. If the superstructure is too large a proportion of the overall weight then the ship will be unstable. You then need to add more weight in the bottom of the hull but that takes the overall weight above the designed displacement and the boat may be stable but "sit" lower in the water than the designed waterline.
                  I had this very problem with my model destroyer. I did lighten the superstructure by replacing metal (brass) funnels with plastic funnels. But I still needed to add significant ballast deep in the hull to give the ship lateral stability. And she is significantly lower in the water than she should be. Ships in which the beam is a small fraction of the length are prone to this problem.
                  #55097
                    As Ian says, it is how the weight is distributed that is the issue. You only have to look at this model to see that it is very top heavy compared with the underwater volume of the hull.
                    As the hull is not very deep, an external keel may be the only practical way forward.
                    BRYAN ASTON
                      @bryanaston57723
                      Greetings all how can I not locate a 3 ft long sunken boat in 2 ft of crystal clear pond water. If and when I salvage Calypso I will follow all the tips I have received from you all.
                      Bryan
                      #55180
                      Geoff Sleath
                        @geoffsleath41411
                        Posted by Colin Bishop, Website Editor on 13/01/2015 09:40:59:
                        My only knowledge of the 'Calypso' was from seeing Jaques Cousteau's TV programmes in the 1950s (at least I think that's what I remember.) Weren't most of the activities under water in any case? I obviously misunderstood the problem. If the model is top heavy before you start then that is difficult to overcome without a dummy keel similar to the one I've made for my barge.
                        Bryan: As for finding your sunken model.
                        Presumably you know roughly where it is and so it should be easy to spot if the water is clear. So take a change of trousers, shoes and socks, plus a towel and go for it. At least the water's only 2 feet deep. It might be a good idea to take a stick both to prevent your getting wet above the knees and as probe to locate the model.
                        Geoff
                        #55197
                          Yes, as per my original post, the model is prone to instability to start with! Kit manufacturers don't always get it right. I can think of a couple of other examples which I'd best not mention.
                          It is surprising how often modellers come unstuck on stability issues which is why we ran an article on it in one of the recent annual Special Issues of Model Boats. People build a model, fit it out with all sorts of extra R/C functions which add weight high up and then wonder why it falls over on the pond!
                            Nothing new. It's probably why the Mary Rose sank.
                              The annual Special Issue which Colin mentioned in the earlier post is the 2011 exclusive to WH Smith, Construction Special. The item was very well written by Richard Simpson.
                              Tony
                              #55205
                              Charles Oates
                                @charlesoates31738
                                Theres a calypso in our club, it was very tender when built, but now successfuly modified.
                                First the lead- acid battery was relpaced with a nimh to keep the weight lower in the hull.
                                Secondly, the superstructure was lightened, cutting out sections where possible,and replacing metal items with plastic.
                                It now sails quite nicely.
                                Charles.
                                #55214
                                BRYAN ASTON
                                  @bryanaston57723
                                  Greetings all
                                  I know exactly the spot where my calypso sank give or take 1m, our club salvage expert wore the club waders and following my directions searched a large area of pond but was unable to locate anything, very strange, tomorrow, the
                                  salvage expert will launch the dingy and extend the search area. Wish me luck. the calypso is the only ready built boat that was in my fleet ,the others were scratch built which I more or less threw together as I have only been into model boats for just over a year and I had no idea what I was doing,they all sailed perfectly without any ballast ,just 7.2 v batteries. Life is a mystery.
                                  thank you all for your comments
                                  Bryan
                                  #55215
                                    Bryan
                                    Two possibilities spring to mind:
                                    Firstly sometimes when model boats sink they hydroplane under the water and can travel for some distance before hitting the bottom, this is especially true in water that has an undercurrent.
                                    Secondly someone else has already recovered it.
                                      A glass bottomed bucket would be very handy in your search
                                      You may also find all those brass props that have been lost over the years?
                                      BRYAN ASTON
                                        @bryanaston57723
                                        Greetings all
                                        Went to the pond , my salvage expert and I were about to launch the dingy ,glanced at the pond and around 15ft out from the edge a white shape appeared on the bottom of the pond it was the missing boat, to say we were astounded is an understatement'I must be living right.
                                        God only knows how long it will take to dry out , took all the electronics out ,only time will tell if anything can be salvaged.Obviously it will need to undergo elements of refurbishment.
                                        Watch this space
                                        Bryan
                                        A happy bunny
                                        #55263
                                          Bryan
                                          Ref the electrics – remove the batteries and don't use them again. Open up the other units as far as possible and rinse them out under a running tap, then shake them as dry as possible and put them on a paper towel in the airing cupboard for at least a week. Try them again with fresh batteries.
                                          BRYAN ASTON
                                            @bryanaston57723
                                            Greetings Dave
                                            I will follow your advice
                                            Thanks
                                            Bryan
                                            #55456
                                            BRYAN ASTON
                                              @bryanaston57723
                                              Greetings all
                                              Following the sinking of my Calypso and the salvage of same, the twin motors no longer run ,has anyone got any idea what motors were originally fitted , I cannot find any markings on them to give me a clue, they are very small.. Any info would be most welcome.
                                              regards
                                              Bryan
                                              #55458
                                                It would depend on the builder but a couple of low drain 385 types should do the job or maybe Deans Marine Kondors.
                                                BRYAN ASTON
                                                  @bryanaston57723
                                                  Greetings Colin
                                                  I bought two 385 motors online and they were a perfect fit to everything, I can now continue with the refurbishment.
                                                  My next job is to sort out the correct ballast, I have sent for an amount of lead shot which will go under the floor of the battery deck. A 12v battery lying on its side and a few strips of lead flashing and the boat will either sail perfectly or sink under its own weight, I will let you know what happens, wish me luck.
                                                  Bryan
                                                  #55593
                                                    Unless you have already bought it I would advise against a lead acid type battery for two reasons. Firstly it will raise the centre of gravity and secondly, while that sort of battery can indeed be laid on its side one side of it will be heavier than the other due to its internal construction.
                                                    A NiMH flat pack of cylindrical cell swill keep the weight much lower, act as ballast and deliver more usable power.
                                                    Also, you probably won't need 12 volts with 385 motors, 7.2v or 8.5v should be plenty. See here:
                                                    BRYAN ASTON
                                                      @bryanaston57723
                                                      Hi Colin.
                                                      When I first sailed the boat it had two 7.2 v batteries powering it , and acting as ballast and it capsized after a short distance, the 12v battery I am considering using is a 3.4 amph and is quite small and should lay flat on the battery deck. I tried a large 12v battery as ballast in the bath with two 7.2 v batteries and a number of lead strips as well ,. it was very stable.
                                                      I read on a billings forum the other day, that billings recommend a total ballast weight of 4.9 pounds, unless I read it wrong. I am open to correction
                                                      Bryan
