BRUTUS MK 11
BRUTUS MK 11
Home › Forums › Scratch build › BRUTUS MK 11
Viewing 25 posts - 1 through 25 (of 532 total)
  • #88757
      Decided to have another go at Paul Thomason`s famous Brutus model
      Brutus 1 was designed by Paul in 2014 and was a very interesting build
      The design was outrageous at the time, being an Axe Head type of ship
      The sharp Axe edged bows allowed the ship to cut through the waves, rather than climb over the waves
      Made a start by cutting out the formers, using Hardboard, which feels suitable for the task, having no other materials in stock
      Will have to venture out into the wild world shortly, in search of wood supplies
      Edited By Bob Abell on 06/06/2020 09:52:39
      #7186
        Axe Head ship of the future
        #88759
          In what direction will the Brutus 2 be different to version 1 Bob??
          With experimental or non-conformist type vessels there are always things I would do differently the second time.
          Propulsion perhaps???
            Paul redesigned Brutus about two years ago. And it appeared in The ModelBoats Magazine
            It is very simolar to the original, but he added weapon features, torpedos and Chain guns etc and more super structure
            I shall fit Brushless motors for starters and whatever comes to mind, any suggestions?
              Hello Captain Bob
              Here is the final version of the original Brutus
              The hull has the potential for quite high speeds and would suit water jet propulsion
              Looking forward to seeing your new take on this design.
                Hello Paul
                Having finished the MTB model and having got back some of my old enthusiasm and fixed the motor drives on the other models etc…….I was scuppered with nothing to do!
                I thought about a kit, for an easy life, but didn`t fancy it really, then I found the ModelBoats Mag with your latest Brutus build. Having a few pieces of hardboard hanging about, my fate was sealed!
                So I got back into the old routine
                So here we go, boys
                Edited By Bob Abell on 06/06/2020 11:19:21
                #88767
                  After all of the trouble with the rudders I would advise changing the stern and give the transom some extra depth.
                  Cookie
                    @cookie15923
                    Great news Bob , Keen to watch your progress with the build .
                    Regards Dave
                    #88772
                      Hello Dave
                      Where have you been lately?
                      Welcome to the Forum anyway, Cookie
                      Message for Paul…….
                      How`s this for an idea?………With having two motors, why have a rudder anyway?
                      Could use Tank Steering?
                        Hello Captain Bob
                        Tank steering is a good idea
                          Hi Paul, I also think that a rudder up front would work, the gun above could pivot on the same axis?
                            Tracing the keel onto the plywood is a bit tricky
                            The keel is shown in two pieces and on different sheets
                            The solution is to refer to the drawing border, to line up the two pieces
                            See photo….I`ve cut the border off the LH sheet
                            ie…. The drawing borders need to be parallel
                            #88780
                              Captain Bob
                              Putting the rudder in a forward location does have some design merit as it can help with manoeuvrability however the downside is that rudders are most effective when positioned behind the propellers.
                                A rudder anywhere near the sharp end will act as a brake, the flatter hull at the stern is much easier for a rudder to push sideways ??
                                  Here's an interesting thought, chaps
                                  Imagine one rudder between twin props, with the rudder blade being extra long, so that a single prop could act on the blade
                                  What would be the effect?
                                  One prop would steer the craft and the other prop would drive the craft forward
                                  Just a thought
                                    Hi Bob,
                                    How about the other way round ? 1 prop & 2 rudders 😎
                                    My new toy, I just sit looking at it !! Scary or what 😯
                                    #88787
                                      Hi Ray………You`ve taken the plunge into the inknown there, old chap!
                                      It will still work, but with reservations
                                      Have you tried it out yet?
                                      It is the reverse of what I hinted about, especially should the rudders have extensions on the inside to be more effective with the prop
                                      Keep us informed
                                        What I was saying about the borders being parallel, hasn`t worked out?
                                        See below……..
                                        The two pieces are easy to match up anyway…….No harm done
                                        #88789
                                          Having no suitable plywood, the keel is being made up from, two outer layers of 1/8 " hardboard and one central core of 1/8" plywood off cuts…..ie a composite material…….Very stiff and strong…….Hopefully
                                          This is what makes the build at the moment more interesting……..Scratching about for suitable materials!
                                          #88794
                                            Ashley will be happy at the use of hardboard! smiley
                                            Edited By Chris Fellows on 07/06/2020 13:11:17
                                            #88795
                                              Thanks Chris
                                              Hardboard can be a life saver at times…..Especially….This time!
                                                Nothing wrong with superior man made board, as bob is finding out.
                                                Bob. A fair few of my boats have twin props whereby the rudder is extra long between them so at full throw it impinges on propwash, and this works very well.
                                                The Terrapin has incredible manoeuvrability despite the squareness of the hull with this arrangement. A couple of boats have offset rudders just out of the propwash and they work ok as well.
                                                We will find out about front mounted rudders on the Crusader…
                                                  The very delicate 48 inch keel under construction
                                                  Note the three clamping points, essential while planning and sanding
                                                  Have also used 6BA nuts and bolts for rigidity
                                                  #88823
                                                    Just a trial assembly of the hull structure
                                                    These are early days yet and with plenty to think about at the moment
                                                    Some of the formers are made of hardboard from a bedroom chest of drawers
                                                    Note…… Some of the bases are made from the drawer side walls!
                                                    #88826
                                                      Another trial assembly to see how the spars line up
                                                      We are getting there……..Slowly
                                                      But surely……Bob
