The traditional fast launch model is becoming increasingly popular as are other models where the efficiency of brushless motors gives a performance hitherto unobtainable to mainstream modellers without the use of i/c power.
However my builds of the SLEC Fairey Huntsman and Swordsman kits have thrown up a driveline issue which I can’t see any obvious solution to without spending a lot of money! I imagine the same will apply to other smaller models of the same type such as the re issued Aerokits and similar ranges.
The preferred power plant these days is a combination of a small brushless motor combined with a 2S or 3S Lipo pack.
Both my models are really noisy when revved up on the bench although the Huntsman in the water is a bit quieter. (The Swordsman has yet to get its feet wet). However much I check and adjust the driveline using a sleeve between shaft and motor it seems impossible to achieve a vibration free power delivery. I am using heavy duty couplings with rubber inserts as the HUCO type wouldn’t last more than a few minutes with the power these brushless motors put out. Even temporarily substituting a piece of silicone rubber doesn’t do much to bring down the noise levels and the thinnish piece I have available twists too much to be a practical alternative on an M4 shaft.
Looking at it a bit more closely, I’m not sure you can expect more than an average result vibration wise. The coupling efficiency depends on the accuracy with which the rubber section is bonded to the ends and any error will be amplified by the high RPM of the motor. The plastic motor end mount allows for some flexing of the output shaft too, even when well screwed down. These little motors appear to be designed to have an aircraft prop directly attached to the shaft which of course makes couplings irrelevant. So I think we have to suffer the consequences when we try to link them up to a near foot long shaft with a big brass whirly thing on the end which probably introduces its own small intolerances. Precision engineering it ain’t!
On my Swordsman the motor starts up a bit unevenly, smooths out at around one third throttle then there is a high vibration band which settles down to medium vibration at full speed (by which time the noise level has shot up with the RPM). So the unevenness is not consistent through the rev range.
Dave Milbourn tells me that one of the people he sails with has removed the motor shaft and bolted the motor directly onto an elongated propshaft to give a rigid drive although the motor needs to be supported in the boat to absorb the thrust and stop it rotating of course. The motor I have does seem to have its shaft held in place with a bearing at the front and rear and a grubscrew securing it to the rotating case but I haven’t dared to dismantle it. It does have a 4mm shaft so should fit on a standard m4 model boat shaft plain end.
I would be interested to hear people’s thoughts on this.
