Hi All
I have decide to remove the motor mount and large plastic gear, also cutoff the thread end of the 4mm large gear shaft.
Make a new motor mount with a uni joint between.
Then I can use lower kv motors and small ones as well .
Checking out the bin box found Prop Drive 2836-1800kv 438 Watts( 19980 rpm on 3S) for a test motor.
The Watts rating is for 4S, so it would be lower.
It is still over the 6400 rpm mark I am aiming for, but, I can cutoff the maximum range on the throttle of the transmitter.
The 1400kv motor fits the bill nicely.
I will kept playing with this as WINTER is Tasmania has arrived !!!!
Harry Smith
