Battery drill motor
Battery drill motor
Home › Forums › R/C & Accessories › Battery drill motor
  • #30134
    pacific fleet
      @pacificfleet
      Has anyone considered
      using a old cordless drill motor for a boat and the trigger for the
      speed controller. I have mounted one on a board and connected a servo
      to the trigger. It will need some sort of servo saver device. The
      motor has these markings RS-550-7527. it was a 14 volt GMC. I
      am looking at making a PT boat 1 : 32 scale. I will be posting some
      video soon. Comments anybody????
      #5115
      pacific fleet
        @pacificfleet
        Use a drill motor and triger for speed controler
        #30135
        Kimosubby Shipyards
          @kimosubbyshipyards
          I’ve used such a drill motor and set up for some years to run a miniature rope walk (saves turning the handle by hand). What really surprised me was the power consumption, almost 2W with little load.
          Because its “land based” i still use it with old lead acid batteries but have not considered them for boat power units due to size, weight, power and revs. These are high torque motors and require big batteries.
          Kimosubby
          #30144
            Unless you can modify the gearbox heavily you’ll probably find that the unit is incapable of producing any useful speed for the sort of model you are planning. You’d need to be looking at 8000RPM+. Have you also considered how you are going to reverse it?
            If you enjoy mucking about with things like this then go ahead – have some fun, but if ’twere me I’d junk it and buy a “proper” motor and electronic speed controller. Less hassle. To put what Kimosubby says another way, if it wasn’t for the fact that this is totally unsuitable for a model boat power plant (size, weight, power and revs) then it would be ideal………………
