Bait Boat Questions
Bait Boat Questions
Home › Forums › Soapbox › Bait Boat Questions
Viewing 25 posts - 26 through 50 (of 59 total)
  • #46215
    Philip Smith 4
      @philipsmith4
      Ta for that Paul.
      BOF wink
      #46224
        No problem Phil, I have sent you a pm regarding the RiverCat
        #46247
        Philip Smith 4
          @philipsmith4
          Thanks got that, now attempting to get my rubbish printer to scan it and print.
          BOF wink
          #46465
          Philip Smith 4
            @philipsmith4
            Just been away for a few days holiday, meanwhile some of the hardware has arrived from Fleabay, the two motors and their speed controllers to be exact.
            So now all I have to do is find someplace to actually build the thing!
            Her Indoors having put her foot down about my using the chest freezer lid as I did last time. So before I start it looks like I will have to build a bench someplace.laugh
            BOFwink
            #46476
              Try using a piece of offcut kitchen worktop, its good and strong but can be moved about.
              #46485
                As above. I have a bit sat on a workmate and that`s what I use. Worktop is great stuff.
                  Workmate??
                  Talk about luxury and having all the best equipment
                  #46495
                    Paul. As you know, the pay for an MB article is so GENEROUS I can afford to have all the best stuff.
                    When I say worktop, of course I mean Italian Marble, not that cheap chipboard stuff.
                    Philip Smith 4
                      @philipsmith4
                      Thank you for those ideas gentlemen. I now can please Her Indoors, and also have something properly substantial to work on that can still be put away when its not in use.
                      BOF wink
                      #46662
                        I am looking at motive power for the bait boat, which is 800mm long and sits low in the water. What does the readership think about Decaperm motors?
                          Expensive, is the decaperm the big fat one or the 500 sized one?
                          wont an ordinary 540 do?? or one of the 2.5;1 geared ones they do (MFA)
                            A 540 might do ………….but my question is which is best?
                            #46670
                              Agree 110% with Ashley – and that's if you can actually obtain one. The MFA geared ones are noisy but cheap and readily available. They also come with an integral mounting plate and one suppressor capacitor (but they really need the other two).
                              Alternatively Component Shop/ACTion are shortly to import some 755 motors which are almost direct replacements for the old Speed 720 Torque – but a lot cheaper as they have plain bearings. Something like that with direct drive to the prop might be worth investigating. I've tested one on 12v and got 4250 RPM with no load and a current of just 420mA. Torque? I gave up trying to stop it with the usual rag-in-fingers technique.
                              Just a couple of thoughts………..
                              Ref 540 on straight drive – forget it. Not enough guts without gearing.
                              Edited By Dave Milbourn on 28/01/2014 14:08:32
                              #46672
                                Semi displacement hull based upon TID profile, all up weight approx. 6kilos, I propose to use a 50 – 60mm dia four blade prop, do you think that an ungeared 775 would be upto the task.
                                  Should be, on 12v or more, but might be marginal on the bigger prop.
                                    Possible option to gain the extra thrust is to use a 50dia 5 blade
                                      Pricey, dude!
                                        The guy wants the best "build it up to top quality not down to a price" were the words he used. I agree that £17 for a prop is expensive but if the 5 blade provides the best performance…………so be it.
                                        Hence the question about the Decaperm motors.
                                          Decaperms used to be the best some years ago but they are very noisy and vastly over-priced c/w other motors around these days. The best now would be something like one of the Buhler motors but I've no knowledge of their range. Brushless motors reputedly have poor low-speed capabilities unless you buy the type with sensors and a very good speed controller. A 5-blade prop on a 755 would be much more cost-effective!
                                            A big thanks to everyone who contributed to this thread.
                                            The bait boat is now designed but I am waiting for better weather to build the prototype as I don't fancy casting fibreglass in the cold.
                                            Edited By Paul T on 20/02/2014 13:37:20
                                            #57765
                                              I'm back on a bait boat design for a friend,
                                              The criteria is:
                                              8kg load capacity
                                              Stable in rough water
                                              Fast but with minimum splash
                                              Long running time
                                              Room for Fish Finder, Depth sonar and cameras (plus all software and transmitters)
                                              Should be fun
                                              Andy C
                                                @andyc56856
                                                Looks like it will be big this time too, with all that lot going in. How'd you get on with the last one?
                                                Andy
                                                #57767
                                                  Hi Andy
                                                  The last one worked out quite well but ended up being a little slow when fully loaded so with the lessons learned the new design will be fundamentally different,
                                                    First draft of the design
                                                    Twin hulls with sea axe bows, two bottom opening hoppers to carry the load, two brushless motors driving 45mm dia propellers through a weed free duct system, tank steering.
                                                      For the interested here is another view of the bait boat design
                                                      And without giving to much away these are the sections.
                                                      The hoppers have a combined maximum load of 10kg with an optimum load of 8kg
