Alternative receivers for the Futaba 6ex transmitter
Home › Forums › R/C & Accessories › Alternative receivers for the Futaba 6ex transmitter
  • #32485
    Derek Sweeney
      @dereksweeney12003
      Hi,
      I have the Futaba 6ex transmitter and for my last model boat I purchased another R617FS receiver. These receivers are very expensive for just 2 channel operation. Does anyone have any experience of using cheaper version receivers with this transmitter.
      Thank you for any advice.
      Derek
      #5147
      Derek Sweeney
        @dereksweeney12003
        #32770
        albatross
          @albatross
          Cirus work fine with my 6EX, assuming it’s 40meg, I’ve a spare I’ll post you for a fiver.
          #32771
          Derek Sweeney
            @dereksweeney12003
            Thanks for the reply.
            I have now sold the system and changed to a Planet T5 which I am very pleased with and is working well.
            Derek
            #66143
            Neville Taylor 2
              @nevilletaylor2
              Does anyone know if the 2 aerials on the Futaba R617FS can be extended WITHOUT soldering for use in model boats. All the 6 and 7 channel Transmitters only seem to mention ACROs (planes) and Helicopters they never include boats. Unless you want to downgrade to a 2 channel system.
              Neville (2)
              Australia
              #66146
                Unless they are plug in items, and nothing in the advertising or on line instructions says so, no. They are very fine coax cables. A characteristic of coax (and most other cable types) is that the loss over the length increases with the length, so even if a good match for the type was found, a longer one would reduce the sensitivity and range.
                #66171
                Mark Jarvis 2
                  @markjarvis2
                  Hi Neville, so long as the antennas are up above the waterline, even better mount the receiver in the cabin area, up high, assuming it's not a carbon fiber hull, keep the antennas 90 degrees apart then your range will be fine, mine goes so far as to need a turn to find which way it is pointing. I have just bought a Cooltec receiver from Banggood, £16 for 8 channels Futaba compatible, works just like the real thing, only 1/3rd the price
                  Mark
                  #66176
                  Neville Taylor 2
                    @nevilletaylor2
                    Hi Mark.
                    Well i am intending to put it in the cabin area anyway. The hull is a GRP I don't think that will cause a problem unless that is what you mean by a Carbon Fiber. Where do I find Banggood?
                    Neville
                    #66177
                    Kev.W
                      @kev-w
                      On t'interweb >**LINK**
                      #69725
                      chris greaves 1
                        @chrisgreaves1
                        Hi , first post and not sure if I should have started a new thread but…. My Futaba receiver has two antenna`s that have to be at 90* to each other. Can I run these down each side of the hull without the need for two external aerials ?
                        #69726
                        Dodgy Geezer 1
                          @dodgygeezer1
                          It depends what your hull is made of.
                          If it's metal, or Carbon Fibre, or anything that shields RF radiation, your aerials need to be uncovered. If it's wood, plastic, GRP, glass-fibre or anything that lets RF through, they can be completely enclosed in the hull.
                          It's generally a good idea to have the aerials as high up as possible. There is some concern that if you have a receiver well under the water-line then it might not get enough signal if it's 2.4Ghz, since that frequency does not pass through water very well. But other people have said that they have not found low aerials to be a problem…
                          #69727
                          chris greaves 1
                            @chrisgreaves1
                            Thanks, the hull is abs vac formed and the two aerials will be above the water line. If I ditched this TX/RX (it is 2.4Ghz) and went for as receiver with a single antenna would it be wise or not, to fit an external aerial?
