Acoms technisport 2.4ghz
Home Forums R/C & Accessories Acoms technisport 2.4ghz
  • #15195
    Shrek
      @shrek
      Hi,
      I have just purchased Acoms Technicsport 2.4GHZ radio.  On the website I purchased it from it stated it was suitable for cars and boats.  When reading the instructions there is a slip of paper enclosed stating "Not suitable for aircraft or boats".  Can anyone please advise me as I have just started this hobby and not too familiar with the technical equipment.
      Many Thanks
      Tony
      #15201
        Tony. On this very forum there is a review of  the Futaba 6EX 2.4GHz Digital Proportional R/C System, have a search……
        I think that may answer a few questions? Ashley
        #15202
        Shrek
          @shrek
          Hi   Ashley
          Thanks for your response, Ive looked at that review but im still not sure that the set i have purchased is any good for boats. Maybe i will buy a basic 27/40mhz radio.
          many thanks
          Tony
          #15212
          Charles Oates
            @charlesoates31738
            Why wouldn’t the set be ok for a boat?  As far as I know the frequency is fine and the set a decent one. The only disscusion I’m aware of is the use of 2.4 gig in submarines where i’ve heard is not so good. Could the slip of paper have been meant for another country where 2.4 gig isn’t legal?
               Anyway, why not just ring acoms importer or a decent model shop to check. Much cheaper than buying another set.
             Chas
            #15219
            Shrek
              @shrek
              Hi Chas
              Thanks for the reply, i took your advice and contacted the acoms importer and they confirmed that this radio set is not suitable for boats. The reason he gave was poor recepition on water.
              Many thanks
              Tony
              #15225
              Manxman
                @manxman
                Hi Shrek,
                I’m with Ashley here, and thought these radios were suitable for boats.  As I understand it, there are 2 short aerials (about 4")  the receiver and both aerials need to be above the water line,  one aerial horizontal and the other vertical, which means one would probably come through the deck, say inside a plastic tube and disguised.
                If you already have a boat, why not try it in it !, but make sure there is someone else sailing as well just in case you need a push to shore.  You have nothing to lose as you’ve already bought your radio.
                Cheers – Ken
                #15227
                  Shrek. I think the problem for this set may be that the aerials are short and so their siting needs to be chosen with more care than yer ordinary 27/40 mhz sets. However, I would imagine that for most "normal" distances it would be ok, and perhaps it is the case that the longer ranges are not quite so good.. Manufacturers are always cautious in regards to what their stuff is or isnt good for to save rubbish press or claims etc . Ashley
                  #15235
                  Shrek
                    @shrek
                    Hi all
                    Many thanks to  Chas, ken, and Ashley for your advice.  I contacted the shop yesterday and were happy to refund me  which they did no problem, So now i am looking for another radio set, Can any of you recommend a mid range radio set ?
                    Many thanks again
                    Tony
                    #15236
                      Shrek, If i was getting a multi channel radio set I would get one of those 40m frequency hopping (Futaba is it?) types, then you dont have to worry about crystals and all that. A chap on our pond has one and it seems to work great. Ashley
                      #15238
                      Charles Oates
                        @charlesoates31738
                        Me too, a synthesised (?) set seems to be the future, no sets of crystals to buy at £10 plus a time, and lots of frequencies to choose from. I’ve not heard of any problems.
                         Chas
                        #15242
                        Shrek
                          @shrek
                          Hi   Ashley and Chas
                          Many thanks again for all your help,  I think i will take your advice and go for a futaba 3GRfs 40fm .
                          Thanks again, Hope to speak to you again
                          Tony
                          #15746
                          Wideawake
                            @wideawake
                            Hi chaps
                            Some confusion above I think!   R/C doesn’t operate on 40m (meters) it operates on 40 MHz which is very different!   However don’t worry, no one will sell you a 40m r/c rig – it’s the amateur radio 7MHz band.   Also AFAIK 40MHz synthesised sets don’t frequency hop – thats a technology used in some 2.4GHz sets.   They are simply switchable between the permitted channels without the need to change crystals.  Nonetheless a very useful facility IMHO.   WRT the set the OP asked about, I can’t comment about that one specifically but I have done a fair amount of work with a Spektrum DX6 investigating the range in boats (see this month’s MB mag) and wasn’t able to induce it to lose lock at maximum eyeball range on my test boats.
                             I suspect that, following some reports of range problems (more specifically temporary loss of control for a few seconds) in boats, the manufacturer or importer is playing safe with its advice.    To be fair, Horizon Hobbies say the same about the DX6.   In spite of this many are being used in boats successfully.   For more info see the article mentioned.
                            Cheers
                            Guy
                            #15764
                              Guy, No confusion here, typo of course, should have been 40M. need a jolly long aerial for 40 metres!!!!   Ashley
                              #15769
                              Mike Davidson
                                @mikedavidson22772
                                    Tony, you asked a good question, and as yet no-one has answered youBack in the bad old days , everybody wishing to operate a radio for any reason needed a licence, I still have my radio control licence. the frequencies were 10 KHz apart inwith the American CB frequencies, they followed the resistor colour codesto readily identify the frequencies Black was channel 0 Brown 1 red 2 orange 3,
                                yellow  4, green  5  Blue  6 I don’t think there was a violet grey or white, but if you look at the old AM frequencies, you will see the gaps  Channel black was the one with all the problems, it was the same frequency as the CB and there was a lot of interferencewith aircraft which is why the SMAEinsisted on going to 35 MHZ  27 Mhz Black was also on the same frequency as hospital pagers> to the best of my knowledge, nothing interfered with any life saving equipment. I have a precise list of all the frequencies if anybody wants one, let me have your e-mail address If you are still awake, and have not lost the will to live, The radio regulatory board of the home office deals with all licencing, and have been known to prosecute hapless modellers for operating without a licence. As far as I know boat modellers are restricted to 27 Mhz with cars, and aircraft modellers may use 35 Mhz.  Your local model shop proprietor will be pleased to advise you I’m sure. I will find out and operate an advisory service.  Mike D
                                #4986
                                Shrek
                                  @shrek
                                  Can I use for a boat?
