Rick. As an interim suggestion, waiting for someone to reply who has built something similar, I suggest a pair of nice brass three bladers would suit. They look nicer than plastic ones and generally have more pitch than said plastic items. As to size… I would have thought 35mm would suit the motors, assuming they are standard 540`s. I would also have thought that a prop in the 30-40mm bracket would look about right on the model. Its worth bearing in mind that the prop has to suit the motor more than the boat, so if you want a slightly larger prop then perhaps a pair of 600 can-types might be a better match. Does the plan not indicate a size??? I am not a fan of two blade types unless its for outright speed. Ashley
