I am after the following issues from the old Hachette 1/200th Bismarck partwork kit to fill a gap in the ones i need to finish the model: 106, 109. 110,111, 112
These should be the ones that supplied all the boats.
Thanks for taking some interest in the subject but what you have located on ebay are for the “second issue ” Hachette Bismark which is completely different – plastic hull, extensive functioning features like turrets turning, static display – from the original version – ply sheet and stripwood hull, turrets glued straight fore and aft, option of converting to radio control. The numbering system for individual issues differs completely between the two issues and I can’t see any sign of an issue with any of the boats at the ebay shop you found. If anyone else has a complete second issue kit I would be very grateful for your advice on which issue number(s) supply the boats and how well they might compare when finished with the original issue ones
Thanks, I had forgotten about CMK’s offerings and I will check what other sources could supply them. I have found a copy of issue 112 offered at eBay which should be with me by next week.
Author
Please log in to reply to this topic. Registering is free and easy using the links on the menu at the top of this page.
