Submarine hardware/electronics
Home Forums Buy/Sell or Trade Submarine hardware/electronics
  • #28001
    David Bothwell 2
      @davidbothwell2
      As per the title, any unused electronics for submarines, or other miscellaneos hardware, as long as it is reasonably priced,
      #8800
      David Bothwell 2
        @davidbothwell2
        #28037
        Len Ochiltree
          @lenochiltree67043
          Wanted ?
          #28038
          David Bothwell 2
            @davidbothwell2
            Hello Len, could be interested in anything, prefer a “swap” for my Robbe PT boat, but cash would also be on the table. depth control, failsafe, dive tanks or parts for static dive, my e-mail is [email protected]  if that is of use?
            #28049
            David Bothwell 2
              @davidbothwell2
              Hi Len, Don’t understand , have you any parts? or should my want advert have been more specific? Took your earlie advice and got a Gato! Many thanks for the good advice
              #28068
              Len Ochiltree
                @lenochiltree67043
                Sorry no parts, yes you were a bit vague, I to have a Gato and am awaiting inspiration.
                Len.
                #28073
                David Bothwell 2
                  @davidbothwell2
                  I have the inspiration, also a length of clear plastic tube that fits the hull, just debating  which dive system to use, nice to be spoilt for choice, preferred is cylinders, but other projects beckon!
                  #28075
                  60watt
                    @60watt
                    David,did you follow Ashley Needham’s point about how he would do things differently if he did his Oberon over again?http://www.modelboats.co.uk/forums/postings.asp?th=39666
                    If the Gato superstructure plastic is not too thick you might get away without a tank.
                    It would make life simpler.
                    Edited By 60watt on 12/08/2010 21:04:45
                    #28078
                    David Bothwell 2
                      @davidbothwell2
                      Thanks for the tip, sorry if response is a little slow. I will read it and consider options D
                      #28079
                      David Bothwell 2
                        @davidbothwell2
                        sorry told me it had not posted but it always does!
                        Edited By David Bothwell 2 on 13/08/2010 20:33:13
                        #28080
                        60watt
                          @60watt
                          I just want someone to figure out how to measure how much there is above the waterline and come back with a figure.
                          #28089
                            I went for dynamic diving as it`s so much easier, however it all depends what you want to do. An easy system is available (see my previous postings) to get a better “more under than on top” sub.
                            I like impressing the crowds at our pond-side (there are normally 3 or 4 standing about) and so a dynamic diver was adequate to demonstrate the submersible qualities i had achieved.
                            David Bothwell 2
                              @davidbothwell2
                              Thanks Ashley I will take another look at your posts, I have material to do cylinders or air system it is just room really Revell Gato
